Its the same driver I've had here for a couple of weeks but have not had time to use it yet. I have modified my stock pill slightly and have a driver in it at the moment so cant tell definitely if it will fit, but a quick measurement and eyeball I reckon it will squeeze in ok without any mods.
I have that same driver in my cart right now, with a few other bits and pieces. Havenāt pulled the trigger yet though. It seems like the perfect driver to use when you want to over-drive an XM-L, but within reason.
Nice one I will investigate soon, you guys reckon its worth swapping the current LEd for the U2? With that driver or keep current one. As for the spring can I just de solder the old one off & re-solder to that board. Or is there something else i can use for the contact?
I have had both in and the stock led if you like the tint is pretty good.
Using the old spring is probably fine, assuming the base lines up well enough with the contacts. You can pretty much make it work no matter what if youāre creative. While youāre shopping at IO though, throw an assortment of springs into you cart as well. If youāre gonna be modding, theyāll come in handy. In fact you might as well just go through the entire Torch components section and pick up at least one of anything you think you might ever need. You know, tail boots, contact PCBās, brass pills etc. Because it sucks having to wait 2 weeks when you finally need something like that.
Most of all, have fun!
Yup realised this now i think il order a small assortment of things! Probably a new driver for one of my bike lights too as it decided to die on me last night!! Damn!! Thanks for all the advice guys too
I don't know why someone would want a diffuser on a thrower, but just for info purpose, I was playing today and the diffuser lens and rubber bezel assembly for the Olight SR51 fits the HD2010 like a glove.
The resulting beam is perfectly diffused, obviously useful at a very short range (for example it's perfect for indoor use)
My HD2010 is finally complete!
Mine arrived with some āissuesā. It worked okay, but only pulled about 1 amp for some reason.
I promptly removed the led and driver, replaced with a XML-U3, and the Nanjg105c +1 7135 and custom Luxdrv.
Worked great! Until it was hot, then it started to āsingā and dim. My ears took me to the tailcap. The switch had a broken solder joint, so I just replaced the whole thing with a forward clickie, and my light is now complete!
Best thrower I have for sure, but I gotta admit, my XinTD is still not all that far behind, and it arrived pretty much perfect. No fuss.
Meh, itās fun to mod.
BLF rocks.
I started having problems with my HD2010 changing modes by itself again. The springs aren't springy enough. I'm going to replace them with better springs.
Thanks. I might get one.
Hey Andiā¦ do you think a ~25 watt soldering iron could be used to heat the dome?
How hot is your cook plate? Is it hot enough to boil water?
Thanks!!
Yeah, that's what I have been using. Just press the iron against the bottom of the star and the slowly pry it away.
My experience in use a solder iron are not good!
And maybe itĀ“s a translation errorā¦.with cook plate i mean my āstoveā, it have 4 cookplates and yes, it boils waterā¦ā¦and my meal everday.
If my wife is not cooking, i cook XM-LĀ“s.
nice foy were did you get your o rings for it and what size are they
hi, where can i found one for a good price please ? (iām in france ā¦ so if you can give me an adress on internet please )
I just received a gray Trustfire HD2010 from TMart priced at 27 euros.
The light is in good condition - no noticeable dings or scratches. I quickly dropped in a freshly charged Soshine protected 26650 ā5500mhaā and turned it on with no issue. The led looks like a XML2. No brand name or model ref written on it. No lanyard either.
However, i did a quick tail cap current test and could not get more then 2.3A - pressing hard on both the battery and tube. Quite far from the 5A some got three years agoā¦ Note that iām not an expect at testing tail cap currents with my cheap DMM and weak probesā¦
I havenāt looked at it in details, but i find the reflector a bit odd. Usually, when i look straight at a light reflector, closing one eye, i only see yellow reflected all over. With this light, i see an irregular yellow blob in the center - not covering the whole circleā¦ And even loaded with a fat protected 26650, some stuff rattles inside when i handle the light. I even suspect the front lens is not tightly fixed in placeā¦ Gotta do some work on it!
Still a nice light for the price - and certainly a great host for modding.
Any suggestion for a driver swap with a supplier outside the US (iām in Europe)? A 3.5 - 4A one with no disco modes would be niceā¦ 0:)
They are very cheap lights and you may well go through 6 of them like I did. Terrible quality, unless modded. You'd have to mod it to do any real retinal "damage." lol Why not mod with an XP-L HI on Noctigon and see what kind of results you get?
@Rusty Joe: thanks for the idea, it should yield some more lumen indeed. However, this light seems under driven and iād love to push a bit the emitters. As far as i understand, the āoriginalā version had direct drive on hi and then regulated on mid and low. I wish to find a similar driver that would fit this host.
Heat dissipationļ¼
I bought mine years ago from TMART, and only recently popped in a LG HE4 to see how it performs. I never really assessed it in the past with anything other than a Trustfire 26650. The tailcap reading I measured with the HE4 was 6.3A using a 10AWG cable and a DC Amps Clamp Meter. Mines clearly one of the good ones that was available for a time. Iāve not modded my torch.
