SKY RAY 9xT6 9xCREE XM-L T6 2x/3x26550/18650 5000LM 5-mode Super Brightness Flashlight---Brightness Over DRY
Cheaper now at 84 bucks shipped.
http://www.aliexpress.com/item/UltraFire-UF-F9-9T6-9xCree-9-led-XM-L-T6-5-Model-LED-Flashlight-by-3/658054610.html
Now 67$ on cnqualitygoods….can’t resist…
But I am still confused because of the King Kong battery’s they are not protected and this flashlight will choke them out till they are dead, any advice for this issue.
are you serious!? shoot, i might not be able to resist now either darnit
yup it is $67. i wonder if theres a new 12xml coming out thats the reason…
Anyone know if this will work with C cells?
who actually has this light? there does not seem to be many owners of this light? is this the floodiest non modded light out there thats under $150. im looking for a flood monster, but i already have a tk70 and srking. will this be a big improvement or not so much.
the price is just really tempting rightnow
This light kicks out around 3300-3500 lumens OTF, so it’s a monster output light. A great mix of flood with some throw, it’s a serious area light. Doesn’t get too hot. It compares in output to my Spark SP6 however that light throws MUCH further. For the money, fantastic. Humbles the DRY, TJ12 and TM11.
Can’t really fault it actually, except it’s well short of the boasted 5000 lumens.
is it the floodiest light that you have?
No, not my floodiest. The Electrolumens big bruiser is floodier, but obviously not as bright.
I have a custom mag by Vestureofblood with 5 XMLs, which is very floody and about equal to the Skyray- is a custom however.
The DRY is floddy however doesn’t handle the heat well, so you can only use it full belt for 5 mins. The Skyray does it well. I’ve run it for 20 mins on hight without major issues.
i have the skrayking. is this 9xml alot more floodier than the king or not by much? is it worth getting if i already have the king and the tk70?
i am wanting a flood monster type light.
Will Not work with c cells good because it doesn’t work with 2 18650 either. With driver swap could it work but c cells have to low capacity on the required current.
But I will check what current flows and if it physically fits in when I get 4 new c cells next week or so.
This thing is bright, and nice. I love my 3Xml but this thing is my new number one. I blinded almost myself when pointing at a peace of paper… Not recommend for reading in night;)
And I don’t run this baby on the max just with 3x18650 not fully loaded at <4A tail cap current.
Get this its super!
I have this and the TK70. It not only has more lumens but is WAY more floodier! It makes the TK70 look like a pure thrower in comparison. Buy it. You won’t regret it.
thats nice to know. one step closer now to buying this skyray 9xt6. do you use 18650 or 26650’s? is it possible to just use two 26650’s? if so, will this give me maximum output still but with less run time or….?
do you have the skyray king though, because the king is floodier than my tk70 as well. so i rather compare the two skyray’s
I tried 18650’s and the batteries got quite hot so I wouldn’t recommend it. Output is significantly lower with only 2x26650’s but it provides an option for those times you don’t need all the power and want something a bit smaller to carry. Sadly I don’t have the King to compare it too. I really can’t imagine it being noticeably floodier but that’s only my guess.
I tested primary cells, no light with 4 cells insight. Tested with power supply, even under 7V there is no light output or power consumption.
The 1x 18650 extension tube has another thread than the 2x18650 tube so you can’t use just one 18650 cell, or 3x16340 like in my tr3t6(which even works with AA cells)
With driver swap could it work even with 4x1.5V cells, but nobody will tune this monster to work on normal batteries. An easier option would perhaps be another extension tube…
Any free ship codes for CNqualitygoods?
Both sites are the same price after shipping.
so who owns this?
Hows the build quality? Anodizing?
Is it everything you hoped for?
I’d hate to spend 88 bucks on a light and not be thrilled.
Anyone have some good close up macro shots?
I’m waiting on a KD driver for my TR-J12. Not sure what visual increase this SR will have over my existing light before or after the mod.
Anyone have both?
My Soshine 26650 arrived yesterday so I could do some measurements:
Voltage. H. M. L
Fully loaded 6.2A 1.8A. 0.67A
11.8V. 5.95A. 1.8. 0.7A
11V. 4.7A. 1.4A. 0.55A
10.5V. 3.9A. 1.15A. 0.4A
10.1V. 3.1A. 0.95. 0.35A
And it’s bright, everything is bright. I have a 3 XML and you could see everything good during night with it but with this thing everything is bright. For example if you point on a car 40 m away the hole street in front of of you till the car is flooded. I checked the roofs and trees from my neighbors and pointed them in their Livingroom, I could see everything as if the sun shines right in there window.
And it gets warm/hot what we should expect from a 50W+ in such a flashlight.
The driver could be more linear especially in the mid low setting, the strobe and SOS is crap like every time.
I can’t do capacity tests of the soshine because my charger is only the 50W type which discharges only at 1A max. But I could load 3.5Ah in it after playing last night with my Baby, so I think that they are about 4Ah like advertised and tested from others. One of my soshine came damaged, the wrap is ripped…but I can fix it with some tape.
Interesting to see that the review on CPF for this light got 3700 OTF lumens. My ceiling bounce test turned out to be quite accurate.
