Busy busy busy ! For at least one more month = Busy ! then I can sleep in , go for lazy afternoon walks , and do more fun stuff like play with flashlights …
In my test of a new hand held spot light I purchased, I put it up against my Fandyfire HD-2010 and the Small Sun ZY-T16. I’m sure the T16 uses the exact same reflector and a similar driver as the Small Sun ZY-T08. If you want to see the beam shots, just scroll down to the photos I posted a few days ago.
I know nothing about modding but am going to try this one. Where exactly do you solder the resistor on the driver? Is it the bottom of the resistor on the left to the top of the resistor on the right or can you solder anywhere on the left resistor and anywhere on the right resistor. thanks
Those resistors are in parallel, so you can solder anywhere so long as you get one leg soldered to one side and the other leg soldered on the other side. In the pic above one side would be the side of any of the 3 resistors toward you and the 2nd being any of the 3 away from you. I think viffer attached his the way he did simply because it was easier with the size/length of resistor he used.
Will it have any side effect from the increase current? Reduce in driver life-span? Irregular flickering or dimming of LED?
I am waiting for my unit to arrive too.
I shorted out my resistors, got 4.5a at the tail, it worked great for about 10 hours of runtime, 25~30 min a time on high, then I went to go to low so I wasn’t blinded when unlocking my front door, no go :~
I checked the current at the tail with fresh pano 3000mah and got 5.65a then it slowly dropped over 5min to 5.4 and stayed there for at least another 10 min, it got to hot to continue (tailstanding indoors), but when I go for my 30min evening walk it does not appear to dim much at all, although it does warm the hand to the stage I swap hands often.
I need to get a xm-l2 u2 on copper in there (it’s stuck in the mail ) as the xm-l t6 is on alumimium and is going slowly more yellow, and I don’t like warm white
Trying to find the right resistor to do this mod, found the .22 ohm resister in 1/2 watt, 1 watt, 2 watt, 3 watt. Which one should I use and what do the different watt numbers mean?
