who actually has this light? there does not seem to be many owners of this light? is this the floodiest non modded light out there thats under $150. im looking for a flood monster, but i already have a tk70 and srking. will this be a big improvement or not so much.
This light kicks out around 3300-3500 lumens OTF, so it’s a monster output light. A great mix of flood with some throw, it’s a serious area light. Doesn’t get too hot. It compares in output to my Spark SP6 however that light throws MUCH further. For the money, fantastic. Humbles the DRY, TJ12 and TM11.
Can’t really fault it actually, except it’s well short of the boasted 5000 lumens.
No, not my floodiest. The Electrolumens big bruiser is floodier, but obviously not as bright.
I have a custom mag by Vestureofblood with 5 XMLs, which is very floody and about equal to the Skyray- is a custom however.
The DRY is floddy however doesn’t handle the heat well, so you can only use it full belt for 5 mins. The Skyray does it well. I’ve run it for 20 mins on hight without major issues.
Will Not work with c cells good because it doesn’t work with 2 18650 either. With driver swap could it work but c cells have to low capacity on the required current.
But I will check what current flows and if it physically fits in when I get 4 new c cells next week or so.
This thing is bright, and nice. I love my 3Xml but this thing is my new number one. I blinded almost myself when pointing at a peace of paper… Not recommend for reading in night;)
And I don’t run this baby on the max just with 3x18650 not fully loaded at <4A tail cap current.
Get this its super!
I have this and the TK70. It not only has more lumens but is WAY more floodier! It makes the TK70 look like a pure thrower in comparison. Buy it. You won’t regret it.
thats nice to know. one step closer now to buying this skyray 9xt6. do you use 18650 or 26650’s? is it possible to just use two 26650’s? if so, will this give me maximum output still but with less run time or….?
do you have the skyray king though, because the king is floodier than my tk70 as well. so i rather compare the two skyray’s
I tried 18650’s and the batteries got quite hot so I wouldn’t recommend it. Output is significantly lower with only 2x26650’s but it provides an option for those times you don’t need all the power and want something a bit smaller to carry. Sadly I don’t have the King to compare it too. I really can’t imagine it being noticeably floodier but that’s only my guess.
I tested primary cells, no light with 4 cells insight. Tested with power supply, even under 7V there is no light output or power consumption.
The 1x 18650 extension tube has another thread than the 2x18650 tube so you can’t use just one 18650 cell, or 3x16340 like in my tr3t6(which even works with AA cells)
With driver swap could it work even with 4x1.5V cells, but nobody will tune this monster to work on normal batteries. An easier option would perhaps be another extension tube…
I’m waiting on a KD driver for my TR-J12. Not sure what visual increase this SR will have over my existing light before or after the mod.
Anyone have both?
My Soshine 26650 arrived yesterday so I could do some measurements:
Voltage. H. M. L
Fully loaded 6.2A 1.8A. 0.67A
11.8V. 5.95A. 1.8. 0.7A
11V. 4.7A. 1.4A. 0.55A
10.5V. 3.9A. 1.15A. 0.4A
10.1V. 3.1A. 0.95. 0.35A
And it’s bright, everything is bright. I have a 3 XML and you could see everything good during night with it but with this thing everything is bright. For example if you point on a car 40 m away the hole street in front of of you till the car is flooded. I checked the roofs and trees from my neighbors and pointed them in their Livingroom, I could see everything as if the sun shines right in there window.
And it gets warm/hot what we should expect from a 50W+ in such a flashlight.
The driver could be more linear especially in the mid low setting, the strobe and SOS is crap like every time.
I can’t do capacity tests of the soshine because my charger is only the 50W type which discharges only at 1A max. But I could load 3.5Ah in it after playing last night with my Baby, so I think that they are about 4Ah like advertised and tested from others. One of my soshine came damaged, the wrap is ripped…but I can fix it with some tape.
Man I’m so pissed right now you have no idea. I spent a lot of time installing my KD driver in my Skyray 9x T6, being very meticulous and all, only to realize this driver, at least my example of it, won’t work using 3 x 26650 batteries. Occasionally it’ll turn on using 3, but will only illuminate in HIGH mode and not change modes. But basically using 3 batteries it’ll simply flash for a second and that’s about it.
I tested it using only 2 x 26650 (Trustfire 5000mAh) and it works fine using all three modes. Funny thing is the original driver doesn’t work well using only 2 batteries. For this KD driver, I’m pretty sure the modes are 100–30–5% and no flashy modes.
I was able to determine the Medium mode (30%) is just slightly less bright than a Trustfire J12 on HIGH mode.
I’m going to reinstall the original driver tomorrow and just leave well enough alone. The Skyray 9x T6 was a powerhouse with the stock driver and really didn’t need anything more.
UPDATE: With 2 x 26650, I get 10.5a at the tail cap.
UPDATE #2: I ran the batteries down a bit and tried it again with 3x26650, lux reading jumped to 1850 lux.
The only readings I was able to get were as follows:
Skyray 9x T6 stock lux on HIGH - 1295 lux (3x26650)
Skyray 9x T6 KD 9x driver HIGH - 1520 lux (2x26650)
Trustfire TR-J12 Stock 3 x 26650 - 810 lux (3x26650)
I removed the spring from the stock driver and installed it on the KD driver as shown.
Here’s the Skyray all buttoned up with the KD driver.
first thing that comes to mind, is defective driver, since the specs say 3-4 cell, and ~2x the wattage
second thing is protected batteries
I think hkj tested the tf protected 26650s, and he usually does a protection trip test, right?
but…even if the driver was trying to pull 100W from 3 cells, it’d be less current than you’re already measuring, so that’s probably not it
don’t suppose you happen to have 3 x cgr18650ch unprotected?
anyway, if you determine it is defective and they won’t let you return it, you could buy another, and return this one in its place….of course if it behaves the same, you’re out $40!
