Test / Review: Keeppower 18650 3400mAh (Black)
59 posts / 0 new
MountainKing
Thank you master Smile
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
KumaBear
KumaBear's picture
Last seen: 7 years 3 months ago
Hello!
We're expecting these batteries (and many other top-rated batteries) in the US in 1 to 2 weeks.  Please refer to:
http://budgetlightforum.com/node/13527
(Highly Competitive) Pricing should be available within a day or two but we will not accept any payments until the batteries are in our US warehouse.  We'll be asking for "RESERVATIONS" shortly but we will not accept any funds until we're ready to ship the batteries to your door.
The RESERVATION SYSTEM appears to be the best way to:
1) Find out your needs (and adjust the quantities in our FIRST SHIPMENT - we have a couple of days left to do that.)
2) Create a list of potential orders - particularly where the FIRST SHIPMENT may not fulfill everyone's needs for a specific item.  The first people to RESERVE batteries will have the first option to purchase them.
Best Regards,
Bob
KumaBear
CM2010
Last seen: 1 hour 57 min ago
$13.50 each, just ordered a couple.
http://www.cnqualitygoods.com/goods.php?id=1776
Woody
Woody's picture
Last seen: 2 days 10 hours ago
Hope you get them. I’d a problem with an order of some batteries from http://www.sz-eyoung.com/
Basically the cells were returned to the seller by HK post. China post won’t take them either. Apparently the problem is that the restrictions on li-ions are being rigorously enforced at the moment, prior to a big Chinese government meeting later in the month. I assume this is to do with the formation of the new government next month.
Still, communications with Jone (who’s a member her, I think) was excellent, and my paypal account was refunded. He thinks that things should be better after in a month or so, so I’ll probably spend even more then.
Jell
Last seen: 11 months 6 days ago
Hank just released his version of protected NCR18650B~
http://www.intl-outdoor.com/2-pcs-panasonic-ncr18650b-3400mah-protected-...
Shadowww
Last seen: 2 hours 33 min ago
That price is very good, considering how low internal resistance Intl-Outdoor’s protection circuits have
To see what I mean, here’s for comparison, IOS vs Xtar, same cell:
RedForest UK
RedForest UK's picture
Last seen: 2 years 2 months ago
Intl-outdoor are keeppower OEM too I think, so they should be the same as the ones at cnqg.
Shadowww
Who knows Silly they both have great reputation, and price difference is negligible, so it’s a matter of button top (Keeppower) vs raised top (Intl-Outdoor Store) I guess.
baterija
baterija's picture
Last seen: 6 years 4 months ago
They did that when they hosted the Olympics too IIRC.
CM2010
Got a few from cnq shipped yesterday hopefully they'll make it through.
KumaBear
KumaBear's picture
Hi!
I had done a lot of research on “button top” vs “raised top” and even got in touch with HKJ to see what he recommended.  His answer was clear and unequivocal.  It appears that some high-end flashlights cannot be used with the broader “raised top” and the “button tops” are not only compact but they do make good contact with any good spring as long as there is the normal amount of pressure.
I hope this helps.
Regards,
Bob
KumaBear
Shadowww
Raised tops are more mechanically robust though.
SpaceCowboy
Very true.
Hikelite
Last seen: 1 day 19 hours ago
SpaceCowboy wrote:
Very true.
I also like them, especially in series where the cells are end to top.
spaceboy
Last seen: 5 years 11 months ago
Hikelite wrote:
SpaceCowboy wrote:
Very true.
Surely button top are better for that?
Anzycpethian
Anzycpethian's picture
Last seen: 7 years 4 months ago
Do these fit into the Skyray King or any Nitecore Tiny Monster? Experience anyone?
"Do not Weep. I shall draw all Things which perish into myself When I am lifted from the Earth." ~ Begotten (1991)
Anzycpethian
Just for the record, confirmed by my experience:
DO NOT FIT IN ZEBRALIGHT SC600
DO FIT IN SKYRAY KING MIMIC
DO FIT IN ULTRAFIRE SH98 (SIPIK 98 CLONE)
DO FIT IN TN31
gavrook
Fit fine in the TM26 and should fit easily in the SRK considering my longer Panasonic’s fit
RaceR86
RaceR86's picture
How would these cells (Panasonic NCR18650B in general) handle 10A drain?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
NightCrawl
Last seen: 5 years 10 months ago
Very bad. They will get hot and well, you dont want hot LiIon cells.
RaceR86
RaceR86's picture
So whats the point of having the protection as high as 11,5A?
Most cells can do 2C right? (??) So 6,8A should be ok, and pushing the limits a bit higher would probably not be that bad (despite decreasing battery life)? Or am I off now? (I know 1C is what is really recommended).
I know mountain electronics have protected PF (Orbtronic), but protection kicks in around 6,5A...
HKJ
HKJ's picture
Last seen: 5 hours 2 min ago
A couple of years ago the extra current was necessary due to incan bulbs (They require a high starting current).
Today you get slightly higher voltage at high current. You can usual expect about 0.1 volt drop over the protection, before it trips.
I.e. a 12A protection will have 0.1 volt drop at 12A or 0.05 volt drop at 6A
A 6A protection will have 0.1 volt drop at 6A, i.e. it will have 0.05 volt lower output voltage.
For most people this difference does not really matter, but there are some people around here that want everything they can get from the batteries.
RaceR86
RaceR86's picture
Thanks for the explanation HKJ.
What are your thoughts on 8A continuous drain from one of these cells?
HKJ
HKJ's picture
I prefer to keep them well under 2C and use high current cells for 8A (I.e. NCR18650PF).
RaceR86
RaceR86's picture
My intl-outdoor 2900mAh (PD) Protected cells probably have around 11,5A trip current, but those cells are not available anymore. (And they were pretty expensive). I am not aware of any of the newer PF cells with protection at 8A++.
ri chevy
Last seen: 11 months 5 days ago
NightCrawl
ri chevy wrote:
http://www.e2fieldgear.com/panasonic-2900-mah-18650-high-drain-li-ion-ba... States they are good for 10A drains.
But those are unprotected. Enerpower has some 3C 2900mAh cells.. HKJ also tested those.
ri chevy
OK. I thought he was looking for genuine Panasonic PF cells.
