XTAR WK20 CREE XP-G R4 265lm EDC LED Flashlight
* 50000 hours lifespan CREE XP-G R4 LED
* Aircraft aluminium alloy
* Anodize processed
* 265 Lm max output
* 270 mins runtime (Test by XTAR CR123A at Low mode)
* Power by CR123A battery
* Max range: 70m
* Light Intensity: 1220cd
* Impact Resistant: 1m
* Working Voltage: 3.0V
* IPX-7 waterproof
* Head twist on/off
* High 100%, Low 29%, Strobe three output
* Size: 21.5mm (head dia) x 16.5mm (body dia)x 63.5mm(length)
* Net weight: 23g
www.xtarlight.com
info@xtarlight.com
Too bad it doesn't work with 16340's. Frown
Question ?
Is it limited to Primaries [ 3v ] , or can it run 4.2v Rechargeable 16340 [ RCR123A ]
If it comes close to 265L on primaries , its doing real well .
High - Low - Strobe , Sorry no cigar , [ I hate with a passion this mode arrangement ]
Please , please , let go of strobe !
High - Med - Low = Fantastic .... Wonderful ....
Strobe = Junk Mode !
Otherwise looks interesting !
And do resize those photos... they take +2 minutes to load (CPF does get this right)
why you hating on strobe man. i love strobe.
VERY useful!
CR123A batteries have a nominal voltage of 3.0V. 16340s have a nominal of 3.7, and a fully charged no-load voltage of 4.2V. Using 16340s in place of CR123As can poof a lot of lights not designed for them, especially multi-cell lights.
On the other hand, a lot of budget CR123A format lights only work best when fed 16340s because they'll be designed 3.0-4.2V.
ITP EOS A1 knock-off with strobe :( which is the price of the Xtar?
BTW, the ITP supports CR123 and 16340, and has these modes: 1.8 lumen > 35 lumen > 190 lumen with no memory and costs around $29
http://www.lightake.com/detail.do/sku.iTP_A1_EOS_Cree_XP_E_Q5_LED_190_Lumen_LED_Flashlight_Black-27672
It can run 3.0V CR123A and 3.0V Rechargeable ICR 123A batteries.
info@xtarlight.com
www.xtarlight.com
the XTAR WK20 supports 3.0V rechargable ICR123 and 3.0V CR123A, 265 Lm max output and costs around $29.9
resized
CR123 runs for 3.0V and 16340 runs for 3.6-3.7V
It's Head twist on/off.
The A1 goes into overdrive on 16350- I suspect the driver in this might fry.
