XTAR D01 Diving Flashlight CREE R5 350 lumens 18650 Rechargable Battery
Inviting Dealers and Distributors
100m Diving XTAR D01 CREE XP-G R5 LED Flashligh
l 50000 life span CREE XP-G R5 LED
l Electrodeless magnetic control switch
l 350 max luminous flux
l Good condensing smooth reflector
l 250m max range (on land)
l Constant circuit constant brightness
l Power by 1*18650 / 18700 / 2*CR123A battery
l Ordinary anodized Aluminum embedded POM body, anodized aircraft 6061 aluminum head
l Amphibious 100m deep diving sealed compression resisted design
l Safety switch design
l 5mm toughened glass
l 3.7~7.0V voltage range
l 198g net weight:
l 44.77mm(head dia) * 30.00mm(body dia) * 143.50mm(length)
The Photographs taken in the Philippine Sea
In the hotel
Contact info:
www.xtarlight.com
info@xtarlight.com
Hello, I don't quite understand how the switch works. Does it have continually variable output levels?
Nah, it is a magnetic switch which works like a slider with around 15 levels. It may seem infinitely variable sliding switch but it has 15-16 levels if you took the time to slide it very very slowly. It is a nice light. I believe it is HA finihed (had it in hand quite a few times). You have to unscrew the body a quarter turn since the magnetic switch draws current! Drains the battery in a few days! Its very cute nicely machined and generally well made. It can compare to 200€ pro scuba flashlights easily maybe put some others to shame. Well worth the money if you need such a light.
If some1 wants i can grab one and do a review... i have local access to most XTAR flashlights and i can borrow them.
