So can you access turbo from the tailcap switch or is it purely done with the meter leads? I’m still waiting on mine arriving so I can’t yet repeat your test procedure, but you just made me even more excited… J)
Well I've had very limited time with it today. I would say I could access it by normal use of the switch as it's doing the same thing as the meter leads (closing the circuit). It might be hard to notice when you have "found" this turbo mode. The hotspot is so tight focused and bright that you can't really tell if it's because it's focused so well, or because it's running at 4A!
I'm surprised this hasn't generated more discussion.
I played with tested the light again this morning and I just can't tell if it's brighter (i.e. in "Turbo") when I first turn it on after a long pause, or when I click through the cycles to come back to "high". I did however test that the "next mode memory" goes away after 3 seconds which I like; it's not a really long delay like some lights.
Really wish some others would test tailcap currents to see if they find "Turbo" like I have! Also wonder what viffer's mod does to "Turbo".
Basically, if there’s pwm on high, it’s more likely that it’s some kind of m-controller glitch where the programming isn’t run correctly, whereas if it’s not the issue is more in the power supply itself perhaps kicking itself to direct-drive and not bucking at all (you can verify this by measuring to see if output drops with voltage, whereas it was verified earlier it maintains power with the driver working).
Given it’s a glitch, not everyone may be able to reproduce, but I’d be curious if they could. A bug aka “feature” turbo mode. :party:
Ok, I had an idea to use the case fan in my computer here at work. I grabbed the light out of my car, aimed at the fan and ran through the modes quite a few times including pausing with it off for awhile (as I did with test leads to find "Turbo"). I also compared to a non-PWM light I had handy. I verified PWM in medium and low modes, but High and "Turbo" (assuming I actually found "Turbo" - can't say for certain since both are so bright) look identical and I don't notice PWM with them (fan spinning looks continuous).
Mine finally came today, 29 days after ordering! Nice packing job, light is in very good condition, no nicks or scratches. It is much bigger than I expected, especially the reflector, so I can't wait to compare it to my HD2010. Tracking info still hadn't updated from this morning and I didn't bring any 18650 cells to work with me today, so the real checkout will have to wait until I get home this evening. Very please so far with what I see.
Edit: Very hard to distinguish from the HD2010. If anything, the hotspot on the Small Sun is tighter. It passed the streetlight test in front of my house.
If you can then check brightness vs. voltage, the mystery could be solved to some extent (ie, some kind of DD fallback/glitch/issue). It’s also odd no one else cares to replicate this (I don’t have one yet).
How would I go about this? Two meters, one measuring voltage across the emitter connections while I do the tailcap current (to see I've found "Turbo")? Not sure how I'd rig these leads in place as I don't have a helper.
It doesn’t have to be sophisticated/continuous, a few data points would suffice. You need a light meter and DMM, and at 10 min intervals from full charge (after running for a bit to “stabilize”, so really at 2min, then 12,22,32 min) take a current/voltage and brightness measure. Running with one cell if two takes too long and you’re impatient.
If DD, the plot would slope instead of flat graph previously in the thread.
might need to get one after i get my paypal back, looks like a nice light to have. quick question, does the light contain a low voltage protection function built in?
