Hi darkside, can you share some information? Do you have a DMM for tailcap readings? Is the stepdown function working? It’s interesting what you’ve said, as the description online portrays a conservative runtime monster:
Indeed. Would be nice if those that have this flashlight, either by personal means or perhaps through dealership, would be able to share some information.
It's here now but given it arrived with a bunch of other lights, it's in my review queue. I should have preview in the coming days but in the meanwhile, any q's just ask.
TurboBB, I’m really interested in any pictures of the dual head and its interior. It’s been at the back of my mind as a project light. Tc350 tube with a pair of 18350’s for one. If LED’s could be swaped out easily? Or the if the bezels are common to the SF thread pitch?
So you wanted a mini-Mjölnir? That's a pretty killer setup (you heard it here first, it's "texas shooter style" ) and I'm quite taken with it:
Two AW IMR 18350's while protruding out quite a bit just fit. However, with this setup, other than being a bit slimmer and tad shorter than the S-L3, it'd be at a disadvantage both output and runtime-wise. It's still pretty cool in this config though and I did verify output to be around 1200lms:
Last pic shows original config vs. XT20
There aren't any grooves in the bezel but I was able to remove it using the palm of my hand and some elbow grease. The lens and o-ring will fall right out with a gentle tap. The reflector however is either glued or screwed and I can't find a way to remove it:
The driver should be accessible but I don't have a tweezer small enough to open the retaining ring. The bezel is slightly bigger than for SF; bottom right pic shows a XENO bezel just inserted in and resting on top of the original bezel, it's too small to fit.
Well that did answer everything, thank you. I was hoping that they had D26 type dropins, but that was just asking too much. Though 2-2 amp XM-L’s sounds pretty good as is with the shorty option.
i have the xt20 but was wondering how the numbers you got on the tc750x compared to it? higher or lower output? lux numbers? Im sure they are similar but just wondering if I should own both
Doing runtime now and confirmed the ~50% step down after 3 minutes. Output is ~1200+ lms but seems to use PWM even on H (just as with XT20 on both counts). Will grab lux later.
Thanks for the information turbobb, I’ve had my eye on this for a while. Stupid question, but I’m assuming it’s 1200+L before the stepdown? So it’s around 600L after?
Correct, 1200+ before stepdown and 600+ after. Hard to pinpoint exact figure due to peaks/troughs from PWM but I'll get a running average when graph is done.
I don’t like that step down feature at all, advertising this light as 1200 lumens is plain cheating then and with that in mind the price is just to high for 600 lumens flashlight, you can get same performance (xml-u2…) fl. for under 20 bucks !!!
I like the shape and overall look and that handy “under the thumb” electronic switch but that step down thing is deal breaker for me…
turboBB, thanks for doing a video review of this flashlight …
cynicists - these jokers are gaming the specs, they claim 1200lms but then it steps down!!!
pragmatists - cool, a 1200lms light that steps down to prevent overheating but I have option to blast 1200 for 3 min when necessary!
The problem w/example you cited is that a sub-$20 XM-L pumping out 600 can't step up to 1200lms (unless you bought another one and taped it together...)
EDIT: I haven't validated yet whether or not you can re-engage H after step down but I suspect you can.
FWIW, even SureFire w/their M3LT doesn't output 400lms for the entire run since it's non-regulated.
It’s like watching a movie trailer on youtube and then buying “expensive” cinema ticket just to be blazed with exciting scenes 3 minutes here and there, and the rest is boring “already seen” story…
45 bucks is my last offer
Thanks TurboBB, not good news if you’re wanting this as a bike light. . I’m hoping someone finds a way to mod it and get rid of that pesky stepdown as this form factor is exactly what I’m looking for. Not so bad if you’re just walking around as you can just keep stepping it back up to high mode I assume if you want more continued brightness.
I highly doubt that they done stepdown thing just to piss as of, there is just not enough cooling surface for 2xU2, and extensive running this flashlight @ 1200 lumens could lead to overheating. The fact that they made this mode time dependent is telling me that they could not accomplish faster heat transfer from emitters to fl surface! If that wasn’t the problem then you would get longer 1200+lumens runtime while riding your bike at cold weather (better cooling) or shorter runtime at 1200+lumens if it’s warm weather and there is no additional airflow to cool down the fl.
Just guessing :nerd_face:
