Review: Small Sun ZY-T08 2 x 18650 (Parallel)
Don't feel left out in the cold, fellers, I'm sure you have plenty of lights the rest of us don't have. JohnnyMac, I can tell you the ZY-T08 is pretty much the equal of the HD2010. Mine are about the same brightness, but the ZY's hotspot is about 15% smaller and more defined - I'm guessing due to the deeper reflector. I'm also expecting much improved run time with 2 x 3400mAh cells in it. But not really a light I needed: It doesn't blow the HD away and it's too large for cycling, so while it's a neat light, probably one I could do without.
Neither do I :O
You mean the size is more cumbersome than the HD2010?
"You mean the size is more cumbersome than the HD2010?"
Yes, I would agree with that. It's slightly longer and heavier. The shape of the tube is ok in the hand, but the HD2010 just fits like butta in your hand. The HD2010 is one sweet light on many levels. As far as overall ergonomics, I would give it the nod.
I don’t even have a C8 or - dare I say it - a Solarforce :open_mouth:
Copy that.
I have had TF3000´s that have LESS cap than Dinodirect 2400TF´s.
Yet, they gave me less Amperage also.
I have had one good pair of TF3000´s and 2 or 3 bad ones...
I have C8 but no Solarforce or any other P60 shite.
Too much blasphemy!
I agree with this whole heartedly, I just don’t like the p60 concept at all, be better if c8’s were standardized so you could just swap pills and reflectors to suit, their not though so poop on that.
I agree the P60 style lights have horrible heat management, not sure why I'm making a triple XM-L one though :P Thinking is so overrated. :D
I rather like the P60 format for "general use". More compact, more pocket friendly, and better looking (at least to me). I haven't touched my C8's since about April.
Now to get back on topic: this ZY-T08 is one freaking awesome light! Was playing around with it again tonight and just blown away by its throw! I must have found "Turbo" because it was like blasting daylight. I lit up the backside of a house about 600 feet away and could see every detail of everything there. I then pulled out my Jacob A60 and had a showdown between the two and the ZY-T08 smoked it easily.
I did notice a little trouble with mine not coming on until I gave it a little shake, but after shaking it stays on.
If you haven't ordered one of these yet YOU NEED TO!!!
-Garry
Preach it brother!
I think you like this light about as much as I do. I got 2 now. And my 2nd one is I’m guessing 5000 lux brighter than my first. It’s a winner. Just a little under my Catapult V3 in throw I would say.
Well heck let me take some 100yd photos if my neighbors vehicles in’t in my way of the trees.
Here you make the call. Manual exposure 1.2 sec shutter f/4 ISO 400 100yds Mouseover ThruNite Catapult V3 mouseout Small Sun ZYT08.
I'd agree with you, just a hair under the Thrunite, although that Thrunite puts out more overall light.
-Garry
I agree. But you got to admit a $26 light compared to a $105 one is very impressive to be this good of thrower. You can buy 4 of the ZY-T08’s for one Catapult V3. But there is no denying the Catapult V3 is the way better quality flashlight. But you got to love that ZY-T08. The Catapult V3 has a lot more useable spill and is putting out more lumens.
Did we ever figure out how to get to the hidden “TURBO” mode? I have two now, they both perform the same. Tried shaking it, thinking the word “TURBO” in my mind really hard before turning it on, tried to see if I could loosen any part of the head to maybe access a second set of modes.
I still don't know how to get "Turbo" on purpose. Perhaps it is a funky driver that goes direct drive (but wouldn't I get way more than 4.0A on direct drive with two Panasonic cells?). When I was using it last night I was in "high" and it was fairly impressive, but then after going through the modes and/of turning off for a few seconds then turning back on it kicked into "Turbo" and I was blown away - definitely a difference in brightness. I left it in "Turbo" for a minute or two and never saw any ill affects (no turning blow, smoke, etc . . .). I do wish my "high" was consistently the 4.0 "turbo" level.
-Garry
HD2010 & Small Sun ZY-T08 Size Reference:
-Garry
Which light explodes first when you turn them both on?
Well, the HD2010 doesn't work (awaiting modding), so I'd say the ZY-T08 would burn a hole right through the HD2010.
-Garry
