Sorry, I didn't see the link at the bottom of your post - my office is too brightly lit for pale grey tiny text to show up. I'm pretty sure those do - but not in an 18650 size.
But they do 5000 mAh and 250A continuous in just a bit over 18650 volume (pi*18265 = ~660 cm3), and BOATLOADS less than 26650 volume (almost half, in fact - pi262*65, 1400 cm3), being 810 cm3.
Should be pi * r squared, not d squared. so is 3.14159 * (9*9) * 6.5 = 16.54cm3 or for a 26650 pi*1.3*1.3*6.5=34.51cm3
The HobbyKing pack is 9.32*4.7*1.85cm = 81.04cm3 - or about the same as 5 18650s.
Using 5 IMRs in parallel (same volume, though I suspect rather more weight and bulk) you should be easily capable of 100A - just not for very long. At best 40% of the capacity
Apologies for the pedantry - I used to teach this stuff.
Those GTL brand they are claiming 2500mah on AAs or 14500s. So 5000mah doesn’t suprize me since it’s 2X the size? that store has 99.2% positive feedback and for it’s volume per month the negatives are pretty low. About 50 sad customers out of 2500 that’s pretty amazing. Funny how most of the complaints are CR123s, AA & AAAs.
>> Google is a great search engine but unfortunately it doesn’t filter out idiocy.
In either direction — because it’s a series of tubes.
>> being googled here
> means …
Well, nouns get verbed — it just happens eventually.
So for this visitor when he said he was “googled here” he’s using it to mean somethin like “directed” or “taken” or “piped” or transported” or “delivered” — why not? Noun becomes verb.
Delivered is after all what google does with your attention.
And it drops you directly into a linked page without showing you any FAQ, or welcome mat, or front page, or any clue where you’re going. Then you click around and see more ads.
Perfect, innit?
Nobody was explaining what everyone here would already know: no rechargeable battery of that type and size now for sale will possibly hold as much energy as was advertised. “Extraordinary claims require extraordinary evidence” and you won’t get that from people trying to sell you crap.
