Wich of this flashlight to choose? Eastward j01, Eastward j06, KD C8 CREE XML T6 1000 Lumen or UltraFire C8 XM-L T6 3-Mode LED
Hello everybody.
I must choose one of this four flashlights but i do not know:
Eastward YJ J01 32.90$---> http://www.dealextreme.com/p/eastward-yj-j01-cree-xm-l-t6-3-mode-900-lumen-white-led-flashlight-with-strap-1-18650-50512
Eastward YJ J06 32.70$ ---> http://www.dealextreme.com/p/eastward-yj-j06-cree-xm-l-t6-3-mode-900-lumen-white-led-flashlight-with-strap-1-18650-50513
KD C8 CREE XML T6 1000 Lumen 25.27$ ---> http://kaidomain.com/ProductDetails.aspx?ProductId=11097
UltraFire C8 XM-L T6 3-Mode LED 27.36$ ---> http://www.manafont.com/product_info.php/ultrafire-c8-xml-t6-3mode-led-flashlight-118650-p-5271
I read all reviews here about eastward j06, j01 and KD c8.
Which is the best and why? (runtime, quality, power, flood and throw).
Thanks.
Hi xatu, I tried ordering the J01 in January and they emailed and said it wasn't in stock so I got the J06 instead. That may help narrow your choices.
I think it would be possible to narrow those down to two or three fairly easily. I think the two Eastwards are basically the same light in a different body - of those two I'd pick the one I liked the look of best. The J06 has a forward clicky which i do not like in a multimode light.
The J01/J06 are likely more throwy than the C8s. But I don't own a C8 of any sort so can't say.
I vote for the eastward j06
Thanks for responses.
The eastward j06 likes me at the moment but the Kaidoman C8 1000 lumens has a very well review here and it's more cheap.
The new question is now: Eastward J06 or Kaidoman C8 1000 lumens?
Forgot to say welcome to BLF xatu. Have fun here.
Given the 30% price difference, I'd probably go for the C8. I don't have it but the J06 (Which is very nice) is nearly 30% more. Both are good lights but it is a very personal decision as to whether the J06 is worth that much more. For me it is, for others it might not be. I'll try to do a full review of the J06 tonight which may help.
Thank you very much for your welcome Don.
Yes, it's 30% price difference but that is about 5€, it doesn't matter, little money, it is only that i want choose the best. I have seen your Google Docs and the J06's power output is very good (although it could be better if it could drain more amps from battery). I like its design too.
I think that i will order the J06.
Bienvenido, xatu ;)
Check this thread also: http://budgetlightforum.cz.cc/node/1665
I have testet a KD C8 XM-L & a Manafont Ultrafire C8 XM-L, i don´t own a Eastward XM-L.
The KD C8 XM-L drives at ~3900mA.
The Manafont Ultrafire C8 drives only at 1400mA.
Best flashlight of this 2 are both LOL ....Manafont C8 XM-L + the driver from the KD C8 XM-L.
Because the manafont C8 has a SMO reflector and although a nice beam. I have put the SMO reflector in the KD C8, but the beam is not as good as in the manafont c8.
Then i put the driver from the KD c8 in the manafont C8 and....WOW, that´s bright!
But i think, the Eastward YJ J06 has a very nice beam. ;)
Gracias por la bienvenida SashiX.
Yes, more flashlights xm-l and cheaper than Eastward j01 and j06. Too much flashlights!!! haha.
I have a question, who will be floodier Eastward j01 or j06? and thrower?.
Just checked again with a new decent cell (Well, it has maybe four cycles on it) and get 2.35A on high, 1.1A or so on medium.
Is it a good power for a xm-l this 2.35A?. I think the KD C8 gives more than 3A.
Don, if you recommend me the J06 with 2.35A i order today...
this means, that the KD C8 XM-L is the brightest flashlight in original condition.
but if you can chanche the driver, maybe other flashlight is brighter ;)
Oh God!. I don't know what can i do.
Eastward YJ J06 is pretty good and good looking for 32.70$ and the KD C8 seems good too and perhaps give more light on high mode and the price is 25.27$.
One of them must be the choosen, but i doubt even. Anybody have both to compare?
when you don´t chanche driver, i think, the KD C8 would be the best.
another interest.....for C8, there are more DIY parts as for other flashlights. (reflector, pill)
Those last two look like a Palight (XP-G) I have ordered.
Foy
It isn't my plan modify the flashlight. Both are good, but in the google doc file from Don appers the Eastward J06 and produce much lumens if i compare with most of the file. Sadly nobody have the KD C8 and Eastward J06 to compare.
I have the J06 and I have the KD C8 on order but I have not received it yet. I'll be glad to let you know what I think when it arrives if you want to wait.
Thanks jb1.
That could be cool but i can't wait, the orders come to me in two months from dealextreme for example. I need order soon.
