They’re also handing out HK Post tracking numbers, even for small value orders, which are valid. The bottom line is that there is absolutely nothing about LightsCastle that would lead a seasoned shopper to suspect that anything was amiss. Just go ahead and place your order leaftye. I’m a cautious shopper myself, but I really don’t think your concern is warranted in this case.
Yeah, I guess the Paypal aspect helps if things don't work out at all, but it can still be a hassle. Just looks at the hassle with the DD SST-50 light. Even if things will ultimately be made right, I don't want to be the first customer. If someone gets their Lightscastle HD2010 before the end of the month and writes good things, then I'll probably order another one too. I wished you had ordered a couple weeks ago because then I might already have the assurance I'm looking for. Stop sitting on your hands already! ;D
I meant Tmart !
I got my Ultrafire HD2010 from Tmart. About $30.
Lightmalls was for another.
It’s Ultrafire, black and pretty flawless. It has been doing backyard duty, living beside the back door, and turned on high for only a few minutes at a time most nights.
I just recieved my fandyfire HD2010 from Lightscastle.
This thing is DAMN BRIGHT! zero body damage or scratches. The build and feel is just ROCK SOLID! i love this bad boy.
I took some tailcap reading off a fresh KeepPower 18650 protected Panasonic 3400mAh and i can only read high setting which is 3.35mA at the tailcap and SOS mode which i didnt pay any attention to.
Only thing to note is my HD2010 came with a black clicky instead of green GITD rubber, and it came with a holster and the 18650 battery adapter
I received my HD2010 from DD ( 45 days! - long delivery time). I paid 21 $ (with Coupon Code and DD Points).
It is an original Ultrafire. Its heavier than I thought… I’ll try to check it out this evening.
Got mine from T-Mart, and it was only $26 after using the $5 off coupon.
Ordered Friday, arrived Wednesday. Its black-I do not know about drivers and all that—but it is free of branding
—-and I love it!
