Yes, it's 30% price difference but that is about 5€, it doesn't matter, little money, it is only that i want choose the best. I have seen your Google Docs and the J06's power output is very good (although it could be better if it could drain more amps from battery). I like its design too.
I have testet a KD C8 XM-L & a Manafont Ultrafire C8 XM-L, i don´t own a Eastward XM-L.
The KD C8 XM-L drives at ~3900mA.
The Manafont Ultrafire C8 drives only at 1400mA.
Best flashlight of this 2 are both LOL ....Manafont C8 XM-L + the driver from the KD C8 XM-L.
Because the manafont C8 has a SMO reflector and although a nice beam. I have put the SMO reflector in the KD C8, but the beam is not as good as in the manafont c8.
Then i put the driver from the KD c8 in the manafont C8 and....WOW, that´s bright!
But i think, the Eastward YJ J06 has a very nice beam. ;)
Eastward YJ J06 is pretty good and good looking for 32.70$ and the KD C8 seems good too and perhaps give more light on high mode and the price is 25.27$.
One of them must be the choosen, but i doubt even. Anybody have both to compare?
It isn't my plan modify the flashlight. Both are good, but in the google doc file from Don appers the Eastward J06 and produce much lumens if i compare with most of the file. Sadly nobody have the KD C8 and Eastward J06 to compare.
I have the J06 and I have the KD C8 on order but I have not received it yet. I'll be glad to let you know what I think when it arrives if you want to wait.
By the time you decide what you want to buy--there will be a dozen more new ones every other day and your decision will be a 100 times harder to make. Good luck.
