I'm not sure how anyone can take you serious anymore with that avatar! (I get a laugh every time I see it!) And just in case you change it, here it is:
-Garry
(Sorry for going off-topic.)
-Garry
You don’t have Trustfire A8, BLF Edition listed as an option. It’s what most people are asking for.
I could probably due without beacon personally. I do like the idea of it being hidden if it is added though.
I'd say some sort of "press and hold for 5 seconds" to trigger beacon. Beacon being something like 1 second on, 10 seconds off. Definitely hidden well, but easily accessible.
-Garry
I'm in for some (two-three-four?), both options.
I have to agree with JM & GB: FF-L-M-H without memory would be my #1 choice, but I'll be happy also with H-M-L-FF with memory.
Firefly + 26650 will be a great combination. Runtimes up to what? 3 months? ;)
For a primary firefly flashlight the A8 is a pretty hefty chunk. I always wear tactical pants, so I can handle a lot of gear. Bigger lights are no problem for EDC. The A8 really is a big weight that I am always aware of dragging down my pants. This is not an easy pocket carry light.
So no U3 CW option? Just T6 CW?
Talk about nightlight
+1
+1
If I end up with this light, It’s a 90% chance I’m going to change the driver to a Nanjg105C anyway.
I guess if everyone is excited about start mode and memory I have to say I don’t know why.
If a light has memory that I can set, I generally set it for low. And invariably I have to ramp it up and then forget to reset it to low.
If it always starts on high, I want low and have to click through modes.
If it always starts on low, I want high and have to click through modes.
If it doesn’t have any memory, it will start one level past the one I want.
Sometimes, I won’t be sure of the level and will click through all of them once or twice anyway, just to be sure. Especially lights with moonlight where I have to look to see if it is on or off.
And finally, even with all these lights I will always pick up the wrong one for the start mode I prefer at the moment.
So does this include the 18650 tube or is that extra? The OP is ambiguous here.
Hello Rey,
this sounds really good. I hope to get my ordered Trustfire Minis (I think I’m the one, who ordered the most Minis) before this groupbuy will end. At the moment, I look every day in my postbox and hope to find the flashlights or the letter of the customer service.
I’m a tint snob, but even more I’m a UI snob, so actually I don’t care about the driver, as long as a NANJG105C fits, because I’m going to exchange it anyway and have whatever modes and memory I want. The downside is that this adds some cost.
Hi,
if it starts in firefly mode, I might get one, or at least the driver. But starting on high is a no go for me….
What makes this light interesting to me is the firefly mode with a super long run time. Without a mode memory and starting on high makes firefly almost useless to me. As a newbie flashaholic I am not sure I posses the skill set to do a driver swap yet. So I would probably pass on this torch. As it stands it seems the only difference between this and stock is the 3c emitter, a FF mode tacked onto the end, driven a tad bit more and BLF A8 printed on the side. Also having Trustfire A8 and BLF A8 on the same torch seems redundant. A8 should only be used once IMO. I.E. Trustfire A8 / BLF Edition.
Get a 50cent fauxton and run down the batteries if you need a dedicated firefly mode light. Look I just saved you $20+.
I’ll take 1 of option 2.
That includes the driver too? And is there any chance of AU charger plug?
Thanks for the suggestion, but that isn’t what I’m looking for. Let me simplify what I was trying to say.
+1
I’m still in for one of these + 18650 battery tube - so long as it starts on HIGH. If I want almost no light I’ll use a lesser torch or a match. But when I want light I’ll go grab a torch
It has to be either:
- FF-L-M-H, no memory
or
- H-M-L-FF, with (working) memory
..because otherwise the firefly mode doesn't make any sense..
I'm in with either of those options, but not with "H-M-L-FF, no memory"
