Well, good luck finding a replacement driver with true FF mode. I can swing the proverbial dead cat at any of our trusted component vendors and hit a driver that has High mode. Not the same when searching for a driver with true Firefly mode. Just sayin’
Wait a minute - doesn't the A8 have an odd sized driver making the driver swap a little more difficult (I remember something about this in E1320's UF2100 group buy thread. Someone proposed to do the same thing with the A8, but the driver was a hangup). Although, I do see Rey is showing a 16.7mm driver being used. If it does use a 20mm driver, I have been proposing the blank 20-21mm battery contact board from Intl-Outdoor as an option, but this adds to the difficulty of the driver swap for those wishing to do so.
Guess we could revisit the idea of just group buying blank hosts and someone take on installing & setting up modes as requested (modes available on the KD V2 3.04A AMC driver). Then of course there's the shipping issue. Any volunteers?
Perhaps we should put the mode order/memory options up in a new poll and simply go with the poll's result - majority wins. This assumes Rey can get the driver programmed with the modes/memory option voted on.
I am sure the reason he is going with high first is to satisfy those who wanted it the first time around on the Mini order. I really don't care enough to care any longer about mode order. I just don't want redundant "A8" printed on the light. I wish Rey had listened to almost all of us on "BLF Edition". Oh well.
Also, looking at the deal on the charger and cell, it looks like a great deal to get option #2. That's what I'm going with since my charger takes f o r e v e r to charge a 26650.
Aside, I’m one who said I’d like to buy drivers — I mean
I’d like to be able to buy the driver board created for the original “Mini”
not for this new one.
As a side note to the fire fly mode debate. Do you find reflector has any bearing on this?
For instance I’ve got an EagleTac D25LC2 Mini (XP-G S2) with a very mild OP reflector. It doesn’t actually have firefly, but it does have a low, however due to the reflector I don’t find the low all that useful, it’s just hot spot.
On my Klarus NT20 it is also an XP-G (R5) but has a HOP reflector, it does have a firefly/moon light mode which is only a faction of the output of the EagleTac, but due to the reflector it’s a much more usable low level light.
Would a large SMO reflector in the A8 make the firefly less useful than it might be in a different host/reflector texture?
I have a Skyray A0 clone (pure thrower) with a Nanjg V2 driver that has close to firefly mode in low (only a few milliamps) and it puts out a tiny hotspot. In pitch dark it is still quite useful but not as great as my T10 with FF low. Small OP reflector is definitely better but it still works.
Actually,I like the choice of high first without memory... I mean a light with these physical dimensions, I would hardly ever use in firefly mode. I can see why people like FF first in AAA, AA,1x16340 torches, but a 26650 light with FF first and no memory doesn't make any sense to me. Isn't the whole idea of having a 26650 cell to extend runtimes in turbo/high without making the torch too long? It quickly gets annoying, if I have to click 4 times every time to use the mainly used mode. Actually I would kick out firefly mode altogether and incorporate a 2nd medium... but I guess that is just me.
I’m in opposition to you. Even in bigger Lights I’m prefer to start with low. But I guess an A8 with Memory would be an acceptable compromise for the most Flashaholics.
It’s risky to demand memory given that even no-memory wasn’t done right on the first light. 10 sec to reset is better than >1min but hardly considered working.
Also, the point of adding FF isn’t to make it a FF light, which the A8 isn’t, but to make it available for rare usage not unlike strobe. I think it’s worth putting in for that sake, but not turning this into yet another BLF MrLite which most seems to have abandoned because of inconvenient mode sequence.
I also don’t understand why M-L-H or H-M-L-Turbo isn’t being considered. It’s the same H->L sequence: ML HMLHMLHML that works well on all lights, except it starts in the most useful mode. I supposed it’s easy to confuse for an inconsistent order when it’s anything but.
And there it is the never ending mode story. People who want such a big light to start on ff or low have serious brain disease. Use a zippo if you want just a bit light…
No, putting A8 on it twice is redundant. It would be much better to have TrustFire A8 on one side, and BLF Edition on the other side. Again, it’s what the vast majority of people voted for.
“serious brain disease”?
If you don’t understand their reasons that doesn’t mean they have a problem.
And why should I carry a lighter just for making light when I carry a flashlight?
+2
Starting with high, ends with firefly and memory would be great. One question:
Would it be possible to include a low voltage warning (like the Nanjg 105C has). I love this function, because I can use unprotected batteries. I know, I can change the driver and do this sometimes in the past, but maybe it could be included. This would be great and I can live with the driver and will buy some more (maybe 2 flashlights and 2 additional drivers).
