Bah, upon closer inspection I realized the holes where nothing lol. My bad. Thankyou for the help brted!!
I had to make the small spring a little longer to make it work in a P60 dropin.
I just bended a piece of cobberwire, stuck it in the spring and soldered it to it,
so it had the lengh needed.
When i don't use a spring i put a solder blob on the pad. Be sure to not mess with it and do it quick. Works fine with flat head bateries. It's not a very good approach but i did not had any troubles so far from the solder oxidation yet, You can also use a tiny copper or brass (less oxidation issues) spacer if you so desire but make sure the tailcap have a spring. When doing high currents might be a good idea to avoid the excessively tiny/skinny springs. The normal ones are just fine, trim them if space is lacking. Be sure to not have the trimmed spring scratch the battery, bend the edge to the inside a bit.
Do it reasonably quick and don't overdue the heating. Pointy soldering iron tips are preferred. Good solder with some lead and flux is the best and melt pretty quickly.
just soldered an xml with this driver..first ever..it was really easy..I was impressed with my rookie skills..the leads were not connected on my driver, so I had to solder them on myself..I used a piece of 14 gauge copper wire to make the positive connection to the battery from the srping..it didn't work with just the spring..it was a great time soldering..I really enjoyed it..
as far as the driver function goes I really hate the 2 secs on for mode memory..I have never had a driver like this and it's really backwards to me..hopefully I get used to it..
I don't like it either, but I think all of the NANJG drivers are the same way (I've gotten used to leaving the light on for a couple of seconds whenever I use it). The micro-controller can't remember the mode after you cut power to it, so it remembers it after it has been on for 2 seconds. I like lights that remember the last mode after they are Off for maybe 0.5 to 1 second, but I think you have to have a capacitor or something that will maintain power to the controller after power is cut in order to do that.
makes sense..it's just really is awkward..to think I got 2 more of these drivers coming i'll have to get used to it lol
A friend of mine has a little problem:
He changed the driver of a DX XML light, but the spring of the driver is to short - the battery has not a good contact to it.
First solution: Solder a longer spring on the driver, but we do not have such springs. The springs of other drivers are to wide.
Has anyone an idea?
Read post #87 above.
Thank you. I must be blind because I don't notice your post.
I ha the copper wire and didn't like it cus it would change modes when bumped..check out my thread on the spring mod..you can use anything to salvage a spring..I used an old remote control but anything that takes batteries is sure to have a spring in it..
Are there no more pic drivers?
I got this driver (the C-Type) and put it into my "experimental" flashlight (Ultrafire u-80 XML). I used it with two modes
100% was 2800 mA and runs on 2800mAh Soshine for about 50 min, second mode was about 100mA. After the fifty mins of full power it switches back to the lower mode and blinks each 5 seconds.
The brightness was great but it not make sense in my opinion because just 50 mins of runtime is too short. So i decided to make less power by ripping of half of the 7135, and make a 3 mode light.
The result is as follows:
0,05 Amps guess 20 Lumens for about 50 hours
0,44 Amps guess 170 Lumens for about 5 hours
1,44 Amps guess 480 Lumens for about 100 mins
You can do that, yes. Or, you could spend 10$ to a USB AVR programmer and use it to flash the Atmel chip and get any brightness you want from less than 1 lumens all the way to 800+ lumens. It's not hard and you don't need to ne a computer programmer to do it. I have never written a line on code in my life, but still I was able to flash it using instructions here. There's no going back to factory drivers for me. The lowest mode of those are usually brighter than I want as mid.
Hello funzelfreund,
the 105 is a good choice, if you need (or want ) 2,8A - for example to get a real bright XM-L. Runtime isn't the important point, if you want 2,8A.
If you need 1,4A or 1,5A, you can buy a cheaper driver - for example the one of this thread (5 of them cost $13,71 and you can modd them to 3 modes):
For anybody who wants to know, the one i've ordered 3 weeks ago is delivered with a Attiny13A
Its more the fun of modding :).
I´m a software developer and so i just ordered the ATMEL stuff to modify the driver by myself.
Thanx for the advice.
I checked the thread and gave up soon. Is there a really simplified guide how to program these chips along with the stuff needed? I would love to program my Ak-47 drivers.
maybe in 2 weeks, when the stuff arrives :)
Still not all that easy. I wrote up a guide on the Flashlight Wiki based on the information in the thread which I think helps, but I haven't gotten a reliable clip to attach to the chip yet. I've been through 2 of them at $12 each and now have a third one on the way for $20. I did make some progress with my second clip and was able to upload a program to a chip. I'd like to modify the program, but that's no picnic either.
http://flashlight-wiki.com/AVR_Drivers
The NANJG 1.4A and 2.8A drivers set to 3 modes are so close to exactly what I want anyway, that I don't know how much utility there is in programming my own driver, but I'm still drawn in by the possibility of a Low that can be set to anything you want including barely lit. If I could get 2 modes, with the Low being able to be set fairly easily, that would be about perfect.
The downside is that you can't have it memorize a mode based on how long the light is turned off without adding hardware components to these NANJG drivers.
This is where the magic happens. That page is worth it's weight in gold. I was able to flash chips using only that page and so will every one else.
And as I stated in page 6 of the "how to build light with perfect modes"-topic, the clip is not necessarily needed. I got it - the cheapest one from ebay - but soon fuond it useless. Then I just soldered the corner wires straight to the chip (not nearly as hard as it might sound, check the picture from that thread) and connected the remaining two wires directly to the pins by hand. And asked wife to come hit the enter on the command prompt. It can be done without a wife also, but it's more difficult. All the soldering/unsoldering action is not that hard and time consuming as one might think. It's good if one needs to flash only couple of chips. As I have done it quite a few times now, I can unsolder the driver-pill connection, open the pill, solder the wires, flash the chip, unsolder the wires and solder the pill back together in less than 15 minutes. I have to admit I have destroyed 2 drivers when practising, but now I can do it with no problem. Cost of loss about 5 dollars.
I have had no success in editing the code, however. It's always 3 modes with memory no matter what I try to do to get 4 modes without memory. But well... I'm just clueless what comes to writing code. And still, 3 modes including crazy low and possibility to program the modes to your own liking makes it pretty close to perfect anyway.
