Test / Review: EagleTac 18650 3400mAh (White-green)
20 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 6 hours ago
DSC_0698
Official specifications:
  • Made in Japan battery cells
  • 304 Stainless steel button top
  • High current load of up to 5A
  • IC protected against short, over-discharge, over-charge
  • Measures only 68mm in height
  • Steel plate reinfocred bottom
  • Ultra high capacity and high voltage even under heavy loading
  • Voltage: Typical 3.7V (4.2V when fully charged)
  • Capacity: 3400mAh (discharged at 0.2C)
  • Dimensions: 18.6mm x 68mm (+/-0.1mm)
  • Weight: 50gram
EagleTac%2018650%203400mAh%20(White-green)-info
This is the latest cells from Panasonic with the highest capacity.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_0696
DSC_0699 DSC_0700
DSC_0701
DSC_0702
DSC_0703
EagleTac%2018650%203400mAh%20(White-green)-Capacity
The two batteries does track nicely, due to the protection circuit the battery has slightly lower output voltage at high current.
EagleTac%2018650%203400mAh%20(White-green)-CapacityTimeHours
EagleTac%2018650%203400mAh%20(White-green)-Energy
EagleTac%2018650%203400mAh%20(White-green)-PowerLoadTime
EagleTac%2018650%203400mAh%20(White-green)-TripCurrent
EagleTac%2018650%203400mAh%20(White-green)-Charge
Conclusion
This is a very good battery.
Like the EagleTac 3100 battery, this battery is very short for a protected battery, this can be useful sometimes.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 2 years 8 months ago
Thanks for the review. I do have a question if you can elaborate on. How many less charges will a 3400mah battery give you vs say a 3100mah battery of the exact same brand?
HKJ
HKJ's picture
What do you mean?
Less lifetime of the battery? (Sorry I have no data on that).
How often to charge? The 3400 has nearly 10% more capacity, this means that when you charge a 3100 11 times, you only need to charge a 3400 10 times. There is usual no reason to replace 3100 mAh batteries with 3400 mAh types, except if you need "5" minutes longer runtime (How much longer depends on the current draw, check the "Discharge, time" curves for actual numbers).
Also remember that LiIon batteries looses capacity with time, i.e. you might be able to use the 3400mAh for longer time, before the capacity is to low for you application.
There is only one brand of 3100 and 3400 mAh cells and that is Panasonic, all the different battery brands uses a Panasonic cell inside.
ILIKEFLASHLIGHTS
I have heard that the higher the capacity of the battery being charged on a charger will actually mean in time it will take less charges down the road. Is that true? Something along the lines that a battery being on the charger longer throughout the life of the battery and that actually diminishes the life of the battery quicker. Now is that fact or fiction?
HKJ
HKJ's picture
Probably a bit of both.
In the datasheets I have seen LiIon are rated for either 300 or 500 charge cycles, I have not noticed if it follows the capacity of the cell (Generally it is very difficult to get the full datasheet).
Using a higher charge voltage will increase the capacity of a cell and will reduce the lifetime, the opposite is also true, i.e. reduce the charge voltage to 4.1 or 4 volt and you get less capacity and considerable longer battery life.
flashlight man
Last seen: 7 years 7 months ago
Thanks for the review and follow up answers HKJ!!
ILIKEFLASHLIGHTS
So really in theory a 3100mah battery will more than likely give you more charges and a better overall bang for your buck vs 3400mah battery.
HKJ
HKJ's picture
I do not believe that, they are probably both rated for the same number of discharges and they do work at the same voltage.
But if you run the 3400 mAh battery with a 4.1 volt charger, it might still be close to 3100mAh capacity (I do not have any numbers), but will have much longer lifetime.
MattSPL
Last seen: 6 months 1 week ago
Great review, thanks Smile
sb56637
sb56637's picture
Last seen: 1 day 17 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
okwchin
okwchin's picture
Last seen: 1 week 46 min ago
Any good places to pick up these 3400 cells, (or any for that matter) that ships to australia? These cells look nice with their white green wrap.
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
Shadowww
Last seen: 3 hours 36 min ago
GoingGear have them.
http://goinggear.com/flashlights/batteries-chargers/eagletac-protected-1...
ILIKEFLASHLIGHTS
Thanks for clearing the air on my question. So I may have to start buying some 3400mah batteries.
bose301s
bose301s's picture
Last seen: 1 day 22 hours ago
I will say the EagleTac 3100s I have are very well made. They don’t perform any better, or worse really, than any of the other 3100 cells I have, however the short length comparatively, for a button top and the steel plate to protect the PCB do make for a very nice cell. Would I buy more at the price they are, probably not with KumaBear’s Keeppower cells but they are still very high quality.
kreisler
kreisler's picture
Last seen: 7 years 4 months ago
this is the protection board of an abused ET3400 :bigsmile:
*FMI* i got 4 i/o sh
B42
B42's picture
I appreciate the great reviews HKJ as always!
Also, have you happened to see any data on how close to max charge vs life to see appreciable life increase of the battery? I have some cheap TR-006 chargers which always charge to 4.17 and always thought that maybe I’m getting a small side benefit of a bit of extended life too.
HKJ
HKJ's picture
B42 wrote:
Also, have you happened to see any data on how close to max charge vs life to see appreciable life increase of the battery? I have some cheap TR-006 chargers which always charge to 4.17 and always thought that maybe I'm getting a small side benefit of a bit of extended life too.
Not test material, but battery university has some info: http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_...
I do not know how exact and how up to date that info is.
B42
B42's picture
Yes tks, I have seen that before, good info. I was hoping for between the max and .1V off of max range, but I guess there isnt any data. I did run across a study showing Li-ion actually does have some memory for shallow discharges recently though, so I’m not sure that site’s seeming recommendation to discharge a battery 50% before recharge to extend life is a great idea anymore.
lionheart_2281
lionheart_2281's picture
Last seen: 2 days 4 hours ago
Where is the cheapest place to buy these cells that ships to Australia?
__philippe
Last seen: 6 years 3 months ago
Not sure about “cheapest”, but this is a good place to order from anyway:
http://ru.nkon.nl/eagletac-18650-3400.html
Shipping options to AU:
http://ru.nkon.nl/checkout/cart/
Cheers,
__philippe
