I just get my Ultrafire C8 XM-L U2 from lightmalls.com.
In the low-light conditions, it is able to reach around 100metres but it is not too bright.
I think 30-50metres is the best range for me! Do u agree what I am saying???
Mine blazes, should easily do 200-300 meters, estimating from distance tests I did. We are talking 3.6A min, up to 5A depending on the battery - very dependent on the battery. If you get KumaBear's unprotected Panasonics (2900, 3100, or 3400): 4A plus. I get more light, and more distance from a HD 2010 or a Crelant 7G9 but those are the only lights that can beat it for what I have - when mine was working stock of course... . Probably better to use a quality protected battery like an EagleTac or KumaBear's because you get the amps in the 3-4A range which is safer, still very bright though. The UF's and TF's are unpredictable - I got some good, some bad ones... My flames wound up being fakes - trick in finding identifying marks in the labeling, as posted here on BLF somewhere.
Also, the charge level of the battery makes a big difference. Everyting I've seen means these lights are unregulated, not as described on the website as regulated to 3000mA.
nice review. can you get the inside diameter of the tailcap?
also anyone can recommend a more floody type head/reflector that would fit the c8 body?
so i can have a light with options for throw and flood.
I do not own calipers, so I cannot say for sure, but I think the diameter is close to 23mm.
And also, the C2’s reflector looks like it would fit the C8, and it is OP and shorter than the C8’s SMO reflector, a combination for good spill.
Personally, what I did was use baking paper to diffuse the light. Although it does block a bit of light, you can barely tell since it is so bright, and there is still is a hotspot in the middle, though it is quite faint.
Running now with a U3 1C with a KD V2 driver at 3.8A (8*7135 + 2*7135, all at 380 mAh). It does appear to be brighter than the stock C8 U2 light - we compared at 100 meters or so. Wish I could measure the lumens. It's an easy light to upgrade.
Did you every find out what's wrong? It could be the battery (cheaper one), or internal connection, etc. Maybe it's just not what you expected? Not sure of your experience, but you may be expecting a wall of light at 100-200 meters, not sure. I believe technically, a light's "throw" is rated at what distance light at the level of moonlight can be cast on an object, so the actual "throw" on this C8 should be closer to 350 meters. There is also a big difference in the width of light diffferent flashlights project - a Jacob A60 for example is a very small spot, but a C8 light is usually a quite large hot spot, comparatively.
I tested my U2 C8 at .3L at 300m and .1m at 400m. And that was with simple protected ET 18650’s pushing about 3amps. So Toms estimate of 350m should be pretty dead on. Some running it harder on an unprotected 18650 might be able to make 400m on a good night.
Can the Jacob A60 beat this C8? I bought this C8 after I read this preview but I’m planning to have Jacob A60 too.
Any comment???
On throw, yes the A60 will easily beat this C8. I have both lights and both are very good lights. But they are very different. The U2 C8 will throw about 350m and put out about 860L doing so. The A60 will throw about 500m and put out about 280L doing it. So the A60 has a nice tight spot, a little spill, and great throw. It has the bigger head and different die to get these results. The U2 C8 has a nice combo of flood and spot - good throw and good spill.
If you are talking about throw, as I suspect, then the Jacob beats the C8, hands down.
If you are talking about spill and overall light output than it’s the other way around.
Right, let’s try A60
rdrfronty - wish you could measure my LightMalls C8 U2 now. Updated to: U3 1C, KD V2 driver 8*7135 + 2, resulting in 3.8A regulated. It's lookin real good and with an SS head now.
Sounds like you have a really sweet setup now. I did test mine recently. Check out the results on the other SS bezel thread.
So a smaller star will not work? I also have a u3 on a 16mm star that I bought for my hd 2010 but I kind of don’t want to mod it and was going to use it on my c8. We (rdrfronty and myself) are ordering drivers and extra chips from Illumination Sply which is in California but I didn’t want to have to wait for some 20mm stars to come in from Int. Outdoors. Reading about your success has made me anxious to start on mine. Lol. Sorry to the OP for going off topic.
Hi - I'm not sure. A 16mm star would probably work. I like to go with the bigger size stars when I can. With a 16mm, you would carefully have to center it - I've done it by eyeball on other lights and seemed to work ok.
Oh - this weekend, got in my order of UCL/UCL/p lenses (7 of various sizes for a variety of lights) and upgraded my LightMalls C8 (now U3, 3.8A, SS head), also an HD2010, Jacob A60, EDC 18650 from I-O, C2, etc. These are from Chris at FlashLightLens.com - wow! They look perfect - never saw the reflector and LED so clearly.
I think I will wait then for the 20mm stars to come in. I found copper pills for c8’s for a really good price. Do you think it would benefit from a copper pill?
Copper pills? Interesting. Sure they are not brass? Some advertised cheap ones are actually brass - forgot where I saw it, but seen that posted. I've read a posting or review somewhere about the variations in C8's and how these C8 brass pills fit only 1 out of 4 or 5 C8 type lights this guy had. The good thing about the I-O XinTD C8 is the brass pill it includes. I have only a couple of $30 range lights with brass pills. Brass would be great, but copper, all the better! Even if it doesn't match, it may be possible to adapt it. If the price is that good, it's worth to buy it.
I didn’t want to derail this thread any farther so I pm’d you a link. If anyone else is interested I can post it.
Rick
I’m certainly interested.
LightMalls now has a U3 version of this C8 posted. Highly inflated specs of 1800 lumens, 4 amps regulated, which of course can't be true, but still, the U2 verison is basically unregulated and they stated 3 amps regulated. So, if anything, the U3 version's driver should be at least as good...
Specs of size/weight are identical. I would speculate it's the same light, just having a U3 LED which makes it pretty good as a stock light. I love the reflector in this light - seems to be superior to other C8 designs I have.
