I’m not sure that I like that copper heatsink that I am using. It is nice and compact and works VERY well, but the fins are short and closely spaced. That requires high pressure air to get in there. The fan on it is a screamer and is recessed into the fins. I would like to build the engine up with a single fan that can provide air to both the LED and the driver.
I am planing on building a small board that fits on the back of the driver. It will have the ACS712 current sensor and an AVR (ATMEGA328?) that controls everything. It would have a FET for switching power to the driver, one for PWMing the fan, and one for PWMing the LED. Parasitic drain on the battery should be around 20 uA. Dimming via a button or pot. It would also monitor the battery, etc.
And something tells me this thing will make an awesome puke light J)
When I was setting up the constant current mod, I had the current level set at around 2A. That is below the minimum level that the circuit wants to work at. The thing started flickering some. I went to crank up the drive level, but turned the pot the wrong way. Then it REALLY started flickering. The effect was rather awesome, even though it was only doing 5000 lumens at the time and the LED was shining into my sphere.
I kludged up an external PWM dimmer onto the constant current driver… it failed miserably. Any dimming caused the LED to go into puke-flicker mode. Turns out that the stock program in the dimmer is PWMing at 100 Hz… way too slow to maintain a stable output. The constant current driver has a 1000 uF output cap, which 5A of current significantly drains between 10 millisecond PWM pulses.
I need to reprogram that dimmer chip for something like 10 kHz PWM…
I think that spec is only for an SST-90. Perhaps if you could get 15k lumens from an SST-90 sized emitter you’d be able to get that kind of throw, but the array is freaking huge. I expect closer to 100kcd, given that the bare emitter already gives off 15kcd.
I tweaked the dimmer firmware to do 32 kHz PWM. The driver behaves a bit better, but still messes up below around 35%. I tried adding a bigger cap (another 1000 uF) across the driver output… it just made things worse. I need to see what happens if I shorten and clean up all the external wiring… and maybe reduce the output cap on the driver.
I did manage to blow the switching FET in the driver by pulling around 220 watts out of it (maybe 19,250 lumens). I replaced it with an IRF3036 (2 milliohm, 190 amp rating, the original FET was 10 milliohm, 75 amp). I was expecting to see some decent improvement in the driver efficiency, but it was minimal.
I’m experiencing a similar problem with a AL8805 1A buck driver chip. PWM below 25-30 and it goes irregular blinky on me. I upped the PWM and still about the same deal. I might try a DAC output of my PIC, and see if that helps.
Maybe my problem is that it goes into a discontinuous mode? The inductor is only a 10uH one, so next up will be to try a higher value inductor. That, or my data sheet interpretation is messed up, it wouldn’t be the first time .
Just warn me when you turn this thing on and start aiming it at things. I want to pull the shades down and put on sunglasses. Ought to be able to see it here in Tyler, when you fire it up, LOL.
I figure you will have about 5 minutes before the chopper arrives with their little spotlight, to search for you.
:bigsmile: Just don’t turn it on within 20 miles of an airport. The helicopter that comes for you will have Bruce Willis as well as Chuck Norris in it.
