I’m experiencing a similar problem with a AL8805 1A buck driver chip. PWM below 25-30 and it goes irregular blinky on me. I upped the PWM and still about the same deal. I might try a DAC output of my PIC, and see if that helps.
Maybe my problem is that it goes into a discontinuous mode? The inductor is only a 10uH one, so next up will be to try a higher value inductor. That, or my data sheet interpretation is messed up, it wouldn’t be the first time .
Just warn me when you turn this thing on and start aiming it at things. I want to pull the shades down and put on sunglasses. Ought to be able to see it here in Tyler, when you fire it up, LOL.
I figure you will have about 5 minutes before the chopper arrives with their little spotlight, to search for you.
:bigsmile: Just don’t turn it on within 20 miles of an airport. The helicopter that comes for you will have Bruce Willis as well as Chuck Norris in it.
I got in the Big Honkin’ Reflectors (ok, 90mm is not that big) from Illumination Machines. Whacked 5mm of the bottom of one to get a 34mm hole. It cranks out 70,000 lux at 1 meter (around 10 degree beam width). The beam is as smooth as a baby’s behind. I’ll try and get some pics up soon.
Old-Lumens 1.3 mile SST-90 Aspheric Potato Masher Thrower does 39,000 lux at 1 meter. A Jacob A60 does around 35,000 lux at 1 meter. These lights have a considerably tighter beam.
It can run on 12V to 30V DC. At 12V it pulls around 15 amps. I was going to (and still might) power it with a 4S A123 20Ah LiFePO4 pack, but A123 is in a bit of a financial meltdown at the moment and their cells may no be viable in the long term. Or any 4S-6S LiPo pack. Or a car.
Here it is lighting up the sphere ’o many mysteries. What is not obvious is that the room is also lit by 10,000 lumens of overhead lighting. For some reason, those lumens take a back seat to the big guy:
Beam shot with reflector. Ceiling is 8 feet from the top of the reflector. Those PAR20 fixtures are 3 feet apart in the Y axis and 4 feet in the X axis.
Are you sure your sphere's not about to catch fire? It also appears that you have an interesting collection of electrical wiring and gadgetry there. Looks like fun.
Doing a little trig on the beamshot image looks like the beam width (full width) out of the reflector is around 16 degrees (with an SST-90 it is supposed to be 10 degrees). Works out to around a .25 lux spot around 600 feet wide at 2000 feet.
Funny you should ask… the lights sit on a couple of blocks of polyethylene foam to get them up to the sphere port. I started a run (with a different heatsink) and after around 5 minutes of observation went to work on the computer in the other room. Sometime later I heard a loud BANG!
What happened was one of the cheap Chinese clip leads to the fan decided to uncrimp the connection between the wire and the clip (hint, only buy leads that are soldered). LED lost cooling, temp rose to over 100C. The heatsink and LED then did their best imitation of the China Syndrome and melted their way through the foam blocks (perfect, form fitting rectangular hole). About 3/4 the way through the foam, one of the power connections to the LED unsoldered itself. The LED driver wanted to keep 5A to the LED, but saw no current flowing so it kept increasing the output voltage. A couple milliseconds later, the voltage exceeded the 35V output capacitor rating and the cap blew with a satisfying BANG (I’ve since added a diode that keeps the output voltage below 35V.
I did a couple more lux tests. With no reflector (120+ degree beam) it did 7000 lux at 1 meter.
With the 90mm aspheric it did 50,000 lux. I can’t get the lens close enough to the emitter to project a tight image since it is mounted in the SST-90 maglight head. The beam was around the same size as with the reflector, but with less spill.
I cranked the output voltage setting down to 33V (a little above the led array Vf) and fired it up. Voila lotsa light. Cranked the current up to 5A. Voila, mega freakin’ lotsa light. Efficiency is around 90%. The heatsink barely gets warm so it doesn’t need much in the way of airflow to keep it happy.
Next I tried it with the dimmer. It works a lot better, but below around 35% I get an occasional blip (maybe every couple of seconds) but no puke mode flicker. It is worse at 35 kHz PWM than at 120 Hz. I need to play some with different PWM rates and see how it behaves.
