My Enlan and SRM knives seem to hold an edge a bit better than the Ganzos I've come across as well.
My sample size, at around a dozen, is far smaller than yours !
I’m impressed with the smoothness of my G710 too.
Which version of the G704 do you have? The early ones with the thinner 3.7mm blade came with some vertical blade play. My newer model with the 4.0 mm thick blade is rock solid.
It is probably an exception, a lucky defect, because all Ganzo knives with axis-lock are known to have “very” stiff omega springs to the point that the axis-lock can’t be released with one thumb and it is still stiff with 2 thumbs. It is true for my G704 and G710. Contrary to the Benchmade axis-lock that can be released with 1 thumb.
My BM 746 mini onslaught was (out of the box) “uber” smooth to open/close and the axis-lock release was (and is still) perfect, soft but secure.
Is it the first version with the brand name engraved on the top of the blade (that can be seen “knife closed”) or the revision with the brand name engraved at the bottom of the blade ?
Except for a factory defect, the vertical blade play was fixed with the revision.
Well. Some toughts:
1) I have SRM, Enlan, Bee and Ganzo knives. From ganzo i have only the g710 and it’s incredible smooth, however i have the enlan el04 and the axis system is much more… mmm unpleasent to use but however again has more size of the blade on the lock and for me it’s more safe the el04 than the g710 (less blade size on the axis lock).
2) If the ganzos are really 440C steel and it holds an edge worse than the enlans: a) It isn’t true that it has 440C
b) The heat treatment must be bad
c) And somebody says that in China there isn’t 440C steel really, and they call 440C to the 9CR14MOV (still better than the 8CR13Mov)
3) SRM seems to be toys for the knife size for me, they can make bigger knifes.
I don’t know… but i like the Ganzo G711 and G707, and thr G704 but i only have the G710.
I think my next folder is going to be Ganzo g711 or g704 or g707…
So you like a cat's *** and knives. You have some screwed up interests...
WOW!!! I like very much the g712, what a pointy blade!.Mmm it remembers me to the espada from cold steel,the handle too.By the way the handle of 712 seems to be very good and grippy.
That 713 looks nice! I want to buy it but I am a bit afraid and reluctant of the chinese knives closing on my hands (Had a close call once) How is the quality and workmanship of those knives compared to say a Benchmade or a Mcusta? Or is it more like a kershaw?
Thanks
I almost was thinking to purchase the ganzo g712 but i dude about its thin blade (only a little part has 4mm) and the thin and weak point (but at the same time i love it). I like very much the g711 for its flat and more strong blade. I prefer the handle of 712 about the handle of the 711. And the old 704, well, i have in my wish list from some time, i like its blade shape.
In general i don’t like the ganzo’s axis lock (i have the g710) due to the lockbar doesn’t engage very well on the top blade (i said before a prefer the enlan’s axis lock).
I don’t know, i only know i’m going to buy one of the 3 models (g704, g711 or g712). Have you tested the three models? I know that isti have the 704 and 711 and he is waiting the 712 (i don’t want the 713 because i have tons of those blade shapes). I saw a youtube rusian video about the g712 but i don’t understand it.
By the way i’m going to buy a mora knife too, i must test it for seeing if it is as good as people says.
I have a 712. Very sharp with a little strop work but be careful. Easy to cut yourself.
A lot of Chinese-produced knives are marked “440c,”
but AFAIK there is no 440c in China.
G712 looks interesting, like a pocket scimitar.
Currently own a G704 and the ergonomics are excellent (copied from a HK/ Mike Snody design), andthe blade is super thick and the knife is quite solid overall. The only issue I have is that the axis lock pulls back too far to clear the blade , and the springs on mine are apparently a little soft in that it doesn’t have the same satisfying and solid click as the SRM763. No blade play on mine either. As much as I like it, it sits in a drawer while the EL-01 is my go-to knife for larger knife tasks
I have bought the ganzo g704 now to the end, and yes, and the ergonomics are near to perfect. But, it is small overall. The blade shape remembers me to the enlan el03 but, this enlan that i own shows better than the ganzo and more beautiful (and bigger!!!). Solid lock up and good sharpness, it’s a good knife but a bit small.
I have seen the new ganzo g714 and g715 but i prefer the g711 and g712 (that i haven’t ).
It’s Chinese 9Cr18Mo, which is pretty close to the 440C formulation.
I like it, possibly my favourite steel.
It’s a pity that I’ve only seen it on knives that are copies of Western premium knives. Most original knives from Sanrenmu and Enlan use 8Cr13Mov which is, it must be said, a good budget steel (comparable to AUS8, with better corrosion resistance) but still a budget steel. I’m considering an Enlan EL08 though, 9Cr13Mov in a big framelock.
I’ve got to admit that if it’s not American, Japanese or German I’m usually not interested, but these look decent. My one Chinese knife (at the moment) is a Halligen Slip KISS.
Ganzo 711 or 712 are supprisingly large closed with the curvy handle. Sizewise I find 704 more suited to me. The ergonomics of the curvy handle on 711/712 is nice though. The large handle means more weight too.
My 714 has a tiny bit cheap feel conpared to the other Ganzos. It just seems to miss something on the finishing steps.
Just received the Ganzo G712 and I have to say I love this sexy beast of a knife! It’s built like a tank and it fits my hand like no other knife I have. Thumbs way up!
