OK.
While waiting, I tried it blindfolded with one 0.22Ohm
Now I get figures around 2.5 -> 3.2Amps or something like that.
I get once and a while the lower 2.4 something and when I cycle modes, it gives over 3 Amps.
Still I think it got better.
edit: those are with Trustfire Flames. Too bad I just ran out of proper Xtars, I will have to re-test when I get them againā¦
gords1001
(gords1001)
November 22, 2012, 9:07pm
283
Viffer said something about the circuit being very touchy with regards to resistance, so not too good cells give a higher reading.
I did find out I have to order some Panasonicās or sanyos, the cells I thought were good have touchy protection circuits when you get over 2.2a.
DrJones
(DrJones)
November 23, 2012, 11:25pm
284
Got mine today.
Measured sometimes 2.7A, sometimes 2.0A on high (0.95A/0.45A for med/low)
Flux: 660lm/320lm/150lm
Throw: 33kcd/370m
Unfortunately I donāt know what current the light used at those flux and throw measurements, but the flux measurements didnāt have much variance.
Hm. I wanted it to be on par with the FF STL-V2 and sell that one (because I prefer the T08 form factor), but now I canāt. Iāll probably try to mod it (when I find time for it).
If someone of you guys need a 0.22 Ohm resistor but donĀ“t want to wait forever ordering from China or donĀ“t have Electronics shop near you, PM me.
I can send some of those to you, probably wonĀ“t need all 20 anyway
awi01
(awi01)
December 3, 2012, 6:08am
286
this is mine coming from manafont today.
what do you think, is it a plastic reflector or alumunium reflector?
also my evgreen flat top battery wont work on this flashlight,
so iāve been thinking to get this one Sanyo UR18650FM 2600mAh Li-ion or this one Panasonic NCR18650A 3100mAh Li-ion or i should go with the unprotected one.
which one would you suggest better for small sun zy-t08?
gords1001
(gords1001)
December 3, 2012, 6:53am
288
Plastic. Any button top cells will run this, but the smaller the button the better.
Donāt worry about the plastic reflector, it works, be happy.
awi01
(awi01)
December 3, 2012, 9:38am
289
viffer750
(viffer750)
December 3, 2012, 9:08pm
290
gords1001:
I added a little solder to the edge of the driver, to make it a good press fit. No difference in out put, I also cleaned the anodizing where the switch PCB contacts the body, no difference. I fitted a pot, minimum setting was 0.5ohm, that raised the output from 1.94a to 2.43a on good cells, and up to 3a on crap ultrafire Greyās, guess their good for something. :bigsmile:
Iām waiting for johnnymac and viffer to get back on the readings of the pots viffer found.
Mine read 0.45 ohm - 49.5ohm in a 270 degree sweep.
The ones viffer found are rated 20 ohm and and 22 turns of adjustment - much better resolution.
You definitely need to get closer to .22 ohm.
Let us know if you find something. Iāll probably be ordering weekend after next (payday).
The above mentioned ebay pot looks good. 360Ā° full turn -> 0.7-0.8ohm, minimal resistance ~0.03ohm, max ~19.3ohm,
gords1001
(gords1001)
December 3, 2012, 9:27pm
291
Thanks viffer, Iāll go find the link again and order a few for stock.
Edit :- just ordered 8, Ā£2.54 8)
Canāt wait for them to arrive now, give this light the current it deserves. J)
JohnnyMac
(JohnnyMac)
292
Mine arrived last week but I havenāt had a chance to install any of them in any lights yet.
how2
(how2)
December 19, 2012, 12:36pm
293
There is an ultrafire version which is the same as the small sun at Banggood for $24.99
garrybunk
(garrybunk)
December 19, 2012, 1:12pm
294
Is that yours or a stock photo? If it's yours, any report on tailcap current, build quality, etc . . . ?
-Garry
how2
(how2)
December 19, 2012, 1:42pm
295
garrybunk:
-Garry
It's mine, same as the Small Sun 2.02amps on with one battery.
Pulsar13
(Pulsar13)
December 19, 2012, 2:35pm
296
Hmm, slightly better price, about $1, but will wait for further report on the quality.
Well, not like MF ones are consistently good anyway :bigsmile:
Iāve submitted product request at fasttech for T08 and T13 before this, hope it gets through.
koyotee
(koyotee)
December 26, 2012, 9:14pm
297
so, where to by a small sun-t08 best price?
koyotee
(koyotee)
December 29, 2012, 11:41am
300
just ordered it, and 2xncr18650a 3100 from fasttech
koyotee
(koyotee)
January 10, 2013, 8:34am
301
so i received the batteries, will they fit into the small sun?
