Very nice review, and light. Thanks!
thanks for the much awaiting review on this light! when you get the chance, could you post some beamshots up against the tn31 and king please.
Looks awesome .
TK70 vs BTU vs TK75
I want all these together in a ring, and somebody to get killed with a Trident. :bigsmile:
Thanks, been waiting this review!!
+1
Thanks for the great review !
Thanks the. Great review. Really looking forward to getting my U2 version in. If it ever ships……
great review!
i cant wait! i got the same configuration as the one reviewed (nw, regulated driver)
id love to get an AR lens and a gitd o-ring for the lens. anyone have any leads??
the can you please post any other lux measurements of similar lights that you have, like the tn31 you mentioned?
Here are some throw figures measured at 4m (just like this BTU)
- TN31 stock CW ~90kcd
- FF STL-V6 de-domed ~95kcd
- Skyray King NW ~20kcd
- Small Sun T08 stock ~35kcd
And then there is this one, just proving that my meter doesn’t top up at 100kcd…
- X6 with de-domed XM-L U3 w. copper pcb ~210kcd
Thanks for the review, been waiting on this one. Outside throw shots would be nice if you get a chance. Thanks again.
Care to test it further than 4m?
I think 2100 measured TK70 to be 80kcd at <10m, but the reading became 97kcd at 13m.
The greater distance will allow multiple beams to fully converge and give the final intensity reading.
Yeah man, it’s 80+ for the shorter distances, and my copy is 92kcd actually. Not a lot, but still there is a difference.
But 80k cd is quite low. Wonder if it’s really T6 3C.
Fenix TK70 is also T6. But there could be some output differences (slight) within the T6 bin as well.
3.6A is high enough, there probably won’t be much of a difference with the DRY at say 4.x amps. If this is 3.6A with PWM (however slight) then there is a very very slight loss as well. << — I noticed this with the DRY driver……the earliest ones are full blast with no PWM, and the latter drivers are with PWM even in turbo mode just that the PWM perhaps switches on and off at 95% power @ xxx Hz, ie a wee bit cut only… while the lowest modes are like 5% power @ xxx Hz. I do not have the latest 700Hz DRY driver.
So we’ll need the U2 version and see how it does.
mine just arrived! threw some aw 3100s in it and let her rip! great companion to my nw skyray king… one for throw one for flood!
charging up batteries now since they were @ 3.6v before
2 day shipping from ric to usa!
…80kcd isn’t impressive for the price, and the output is just at King’s level…
My NW SR King metered almost a fourth more than his, so please don't take these as absolute numbers.
I would guess that _the's_would hit over 100k lux on a higher-reading meter.
I'm starting to regret not jumping on the pre-order...
Outdoor beamshots added to OP
Thanks for the beamshots.
nice shots
I like the BTU tint more than the others
That mouseover vs the TN31 is jaw-dropping.
Very nice beamshots That BTU is a beast :bigsmile:
