Looks awesome .
TK70 vs BTU vs TK75
I want all these together in a ring, and somebody to get killed with a Trident. :bigsmile:
Thanks, been waiting this review!!
+1
Thanks for the great review !
Thanks the. Great review. Really looking forward to getting my U2 version in. If it ever ships……
great review!
i cant wait! i got the same configuration as the one reviewed (nw, regulated driver)
id love to get an AR lens and a gitd o-ring for the lens. anyone have any leads??
the can you please post any other lux measurements of similar lights that you have, like the tn31 you mentioned?
Here are some throw figures measured at 4m (just like this BTU)
- TN31 stock CW ~90kcd
- FF STL-V6 de-domed ~95kcd
- Skyray King NW ~20kcd
- Small Sun T08 stock ~35kcd
And then there is this one, just proving that my meter doesn’t top up at 100kcd…
- X6 with de-domed XM-L U3 w. copper pcb ~210kcd
Thanks for the review, been waiting on this one. Outside throw shots would be nice if you get a chance. Thanks again.
Care to test it further than 4m?
I think 2100 measured TK70 to be 80kcd at <10m, but the reading became 97kcd at 13m.
The greater distance will allow multiple beams to fully converge and give the final intensity reading.
Yeah man, it’s 80+ for the shorter distances, and my copy is 92kcd actually. Not a lot, but still there is a difference.
But 80k cd is quite low. Wonder if it’s really T6 3C.
Fenix TK70 is also T6. But there could be some output differences (slight) within the T6 bin as well.
3.6A is high enough, there probably won’t be much of a difference with the DRY at say 4.x amps. If this is 3.6A with PWM (however slight) then there is a very very slight loss as well. << — I noticed this with the DRY driver……the earliest ones are full blast with no PWM, and the latter drivers are with PWM even in turbo mode just that the PWM perhaps switches on and off at 95% power @ xxx Hz, ie a wee bit cut only… while the lowest modes are like 5% power @ xxx Hz. I do not have the latest 700Hz DRY driver.
So we’ll need the U2 version and see how it does.
mine just arrived! threw some aw 3100s in it and let her rip! great companion to my nw skyray king… one for throw one for flood!
charging up batteries now since they were @ 3.6v before
2 day shipping from ric to usa!
…80kcd isn’t impressive for the price, and the output is just at King’s level…
My NW SR King metered almost a fourth more than his, so please don't take these as absolute numbers.
I would guess that _the's_would hit over 100k lux on a higher-reading meter.
I'm starting to regret not jumping on the pre-order...
Outdoor beamshots added to OP
Thanks for the beamshots.
nice shots
I like the BTU tint more than the others
That mouseover vs the TN31 is jaw-dropping.
Very nice beamshots That BTU is a beast :bigsmile:
Thanks very much for the review! Frontpage’d and Sticky’d.
Pulsar13:Great review
the. Sorry I don’t follow the general enthusiasm for this $150 light, 80kcd isn’t impressive for the price, and the output is just at King’s level. Given the hype that this was called “super thrower”… hmmmph… not quite there. Maybe beamshots will tell a different story, but right now I’m not too impressed.agreed with pulsar . it falls below my expectations. same output as a king with large throw…well it has a head 3 times the size of a king duhh .it seems to be user serviceable freindly with the old school methods used .the upside down mounted mounted battery springs look gheto!!! why not make custom spings for it…the glass does not have anti reflective coating !!! isnt some thermal paste electically conductive?.the amout of thermal paste smeared all around the leds doesnt want to spend $180 with 3 panasonics 3100s $35 = $200 .the batries have to to notch to provide the 3.5 amps and only the panasonics are up for it…. use a u3 emmiter …whats with this T6 .
its a pimped up light made from a collection of parts tk70 head/spings picked up from a shelf etc . Is there any waranty ???
This is the NW T6 version. There is a U2 version available also, which outputs around 3k lumens.
