I’ve had mine for 2 months now, T6 3C with a 7135*7 105c. I carry it in my pocket daily. I did swap the driver for a KD 7135*6 because I wanted the 5mA low and no memory. I feel that the 2.2 A high is adequate for my use and heat is not so much of a problem.
I got mine with the xp-g2 , added another 380 chip only thing that bothers me is the “Convoy S3” i thought it would be blank like the host I got too.
What holsters are you guys using for these? Hank, any suggestions? I’m using an old streatched up Fenix (2AA) holster that works perfectly.
It can’t be an EDC if it doesn’t have a clip.
Post #91 - I'm still using it, it works really well for this light, fits tight. It doesn't have a flap over the top but because of the tight fit, I don't think it's going anywhere.
I beg to differ.
<a href=Photo Storage target=_blank><img src=http://i185.photobucket.com/albums/x48/gords1001/IMAG0482-1.jpg border=0 alt=>
I can’t stand clips, and this edc’s just fine on that lanyard thanks.
This is exactly what Scaru’s nightstand must look like.
Mine isn't that organized, just a pilHost hosts, pills, LEDs, drivers, and more.
just got one of these today. XML T6. Nice light.
They’re back to 7135*8, switchable between 3 or 5 mode.
shiner - I’m thinking of getting one. How is the heat?
wahoowad: With a 4x7135 driver and a XPG, it gets pretty hot to the touch if left unattended on high. (ambient temperature here is about 28 deg C) With 8x 7135’s it’ll likely get screaming hot if left on high for long.
High mode starts to get quite warm after 3-4min, it probably shouldn’t be left on high very long. Medium looks almost as bright, without so much heat.
I am interested in the neutral T6 but I need to know:-
- Does it have real memory i.e. if I set it for low, would it turn it on low even if it was off for weeks?
Even better, when I swap the battery, does it still remember the previous mode? - Is there PWM flicker at any mode?
- Is it any thinner than UF2100?
- Can I get a clip for it?
Thanks
1. Yes (did take battery off and put it back, remembered mode).
2. No PWM, but does "hum" on medium.
3. No, about 1mm thicker.
4. With little mod SolarForce clip will work.
anybody tried this? I suppose it involves using drill on your light. But unless there is room in the cap, it will be tough. Also, is it easy to drill on HA-III or does drill slip?
Another question, does it have spring in the head too? are there any beamshots of neutral T6
Not yet, but I plan to install one on mine. I have the XML T6 3C. I will drill and tap the tail cap so I won’t need the nuts. I have switched the driver to a KD V2 6*7135. I like the very low low.
Just put my Fenix TK12 clip on the light. Found a forum where they put an LD20 clip on one but it’s the same clip. Hard part is finding a site that sells the clip.
Yes, springs on both ends.
didnt really understand from intl outdoor site how to change from 3-mode-group to 5-mode group. how should i do it?
and is it normal that modes go in this order: med, high, low?
This thread explains mode changes.
My mode sequence was H-M-L.
