Before adding an external current limit pot to the driver, I figured it would be a good idea to try running the one on the board through it’s range. It won’t go below 1.25A.
Around the 2.5A area it gets a bit woogedy. Just touching the pot with a screwdriver or even touching the (isolated) heat sink causes the current to shift around 200 mA. Above or below 2.5A and it is OK.
Dim it, damn it! Who’d a thought dimming a 150 watt LED would be such a pain… I really don’t want to have to design my own boost driver just to get a decent dim.
I took the 100K current limit pot off the board of one of the drivers and replaced it with an external 500K pot. That lets it dim down to 600 mA (about 10%). For the best dimming profile the pot should be an audio taper pot.
There is the same glitch in the current output around 2.5 amps. As you increase the current from 2.5A to 3A, the current drops back down to 2.5A and then starts rising again as you turn the pot some more. This issue looks like it is inherent to the driver design.
There are a couple of issues with using the a manual current adjust pot to do the dimming instead of PWM. First is a potential color temperature shift with LED current. This does not seem to be a problem with the Bridgelux arrays.
Second is the fact that the control processor can’t do things like backing off the LED drive if the battery voltage starts falling or the LED starts overheating… you can only turn the light off. There are some digitally controlled pots out there that might be usable.
Yes we are following, it's just not many understand all this stuff so well I guess. But this is interesting and there is always something new to learn, so I'm
With 12V in it draws around 15 amps. Power can be provided by a 4S - 8S LiPo pack or a 4S A123 20 Ah LiFePO4 pack or a lead acid battery. An pack made of IMR cells or a power tool pack would also work fine. The input voltage needs to be less than around 30V to work with the DC-DC converters that I have been playing with. My 180,000 and 540,000 lumen arrays used a custom buck converter that was driven from dual-redundant 16S A123 packs when in battery backup mode.
I was going to use the A123 cells, but those may not be readily available in the near future.
I’m running a 30E4000 array (‘E’ for 80cri) in a retrofitted floor lamp. Bridgelux claims 4725lm at 2.1A; I’m driving at 2.5A so the Flux-Current chart on the datasheet suggests it’s running around 5600lm. Mounted to a salvaged CPU heatsink and cooled by a small, undervolted fan. A custom pyramid base was constructed to house the power supply and provide stability.
Overall it works pretty well. Light quality is better than the CFLs it replaced; it’s comparable to halogen but it has an slight pink tinge if you do an A-B comparison. I’m curious to know what the 90cri array output looks like.
Kudos to texaspyro for turning me onto Bridgelux arrays last year.
Next project will be an outdoor floodlights based on a couple C9000 arrays.
I looked at the Decora datasheet when I was trying to decide which Bridgelux array to use and it’s an impressive product line (and likewise, I couldn’t find them for sale anywhere). Unfortunately, 98 CRI comes at a price…they’re pretty inefficient relative to their 90 CRI arrays. Around 50 lm/W, IIRC, versus 90-100 lm/W.
Once they’re available I’ll consider trying a few in the kitchen or master bath.
Hey guys. new to the forum - actually I signed up thanks to this awesome thread which is totally in sync with my ideas on building a kickass HCRI array led
For the Decor line I got some feedback from distributors in Europe : Items are orderable, but leadtime is 8weeks so guessing these are coming fresh off the bake plates. Unfortunately MOQ = 40pcs… Maybe if they get stocked MPQ will be much less.
What I have been looking at are these:
BXRAW-3500-00Q0H
BXRA-W1800-00X2H
As far as I can see none of the big distribution (Farnell, digikey, newark) have registered these models.
hey texas thanks for your posts. I get it you ditched PWM running with DC/DC. Im curious to find out exactly which mods you did to the Dalewheat PWM. Still you would recommend this on battery-only application?
