Test / Review: Xtar 18650 3400mAh (Black)
14 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 days 13 hours ago
DSC_0851
Official specifications:
  • Voltage::3.6V
  • Net Weight: 47g
  • Size: 18.4±0.1mm x 68.5±0.5mm
  • Battery Capacity:3400mAh
  • Cell: Panasoinc lithium cell inside
Xtar%2018650%203400mAh%20(Black)-info
This is the latest cells from Panasonic with the highest capacity with added protection and button top from Xtar.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_0849 DSC_0850
DSC_0852 DSC_0853
DSC_0854
DSC_0855
Xtar%2018650%203400mAh%20(Black)-Capacity
The tracking between the two batteries are good (as expected).
Xtar%2018650%203400mAh%20(Black)-CapacityTimeHours
Xtar%2018650%203400mAh%20(Black)-Energy
Xtar%2018650%203400mAh%20(Black)-PowerLoadTime
Xtar%2018650%203400mAh%20(Black)-TripCurrent
The over current protection is at "only" 6A, this will protect the batteries from mistreatment, but gives the battery a slightly lower output voltage at high current.
Xtar%2018650%203400mAh%20(Black)-Charge
Conclusion
This battery has higher capacity and better high current capacity than its predecessor Xtar 3100mAh.
Xtar has added protection to a good cell, making a very good battery.
Notes and links
The batteries was supplied by Xtar via www.lajt.se for review.
Edited by: sb56637 on 08/26/2014 - 17:45
HKJ
HKJ's picture
kreisler wrote:
The same Panasonic cell is in so many other products:
Efest 3400, Eagletac 3400, KeppPower 3400, EnerPower+ 3400, Xtar 3400, Orbtronic 3400, HKE 3400, IOS 3400, Krelis 3400, Wontfire 3400, etc.
And with some small differences between the finished product: different top, different length, different protection circuit.
In most cases you can use any of them, but some lights does require have special requirements.
Overclocker
Last seen: 4 years 5 months ago
hi henrik! no metal plate at the bottom? just a PCB?
HKJ
HKJ's picture
It does look like a PCB with the yellow color.
MattSPL
Last seen: 9 months 3 weeks ago
Thanks for the review Smile
sb56637
sb56637's picture
Last seen: 3 hours 40 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
nqcken
Keepower 3400 Mah cells have that same yellow plate. I have been told that it is a gold plated metal plate and it certainly looks it when looking at the cells up close and personal.
ken
HKJ
HKJ's picture
nqcken wrote:
Keepower 3400 Mah cells have that same yellow plate. I have been told that it is a gold plated metal plate and it certainly looks it when looking at the cells up close and personal. ken
A PCB can also be gold plated metal: PCB is copper and it is easy to get a gold plating on it.
Overclocker
yeah i’ve got some of those cheap trustfires with PCB bottom. after some time they get all scratched up. very soft!
does a magnet stick?
HKJ
HKJ's picture
Overclocker wrote:
yeah i've got some of those cheap trustfires with PCB bottom. after some time they get all scratched up. very soft! does a magnet stick?
It does, but only weakly, because it there is a few mm between the bottom and the metal.
Annie-one
Annie-one's picture
Last seen: 8 years 9 months ago
Detailed review,thx a lot
No Difficulty,no fun.
MountainKing
Last seen: 1 month 1 week ago
Can I order this cell from somewhere say fasttech?
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 3 years 8 months ago
Guys, do you realize how much money HKJ saves us in doing these awesome battery reviews. I can’t think of a better member or smarter member than him when it comes to telling it like it is and giving us the best in detail battery reviews every single time. I am truly thankful that he is here, and I personally want to thank him here for his time in doing all of these great battery reviews. I pretty much go buy what he says. It’s kind of like buying good insurance for batteries when you know your getting what you pay for in advance before you buy.
Thanks again.
Brad
MountainKing
Thanks again.
Brad
+1 on that. Was at work hence the quick posting..
