How did we do? (FastTech.com)
This is terrible and unfortunately it’s not a manufacturer’s picture (most of them are actually unable to provide photos at the standard we require). We’re now on the look out for these and will try to screen the bad ones out as much as possible.
Like @Lumatic suggested there is a small star with the words “Add to wishlist” next to it. It’s right next to the specifications table.
We hear you, and it will be likely moved to the buy button in the next update.
The site is supposed to works best on Chrome, which is the primary browser we use in the office. Let us know if you notice quirks. Thanks!
Jasmine.
Jasmine-FastTech - would be great if you get the latest CREE LED's, U3 1C's, XP-G2's, etc. You have a T6, but no idea what it is?? We need the tint info listed, as other vendors do (1A, 3C, etc.). Your prices are great!!
And try to stock neutral white versions (like the XM-L T6 3C) since those are of higher demand here on BLF.
-Garry
Ordered a few little things on 4th. Sent on 6th, arrived this morning. Everything as should be, well packaged, great communication, and remarkably fast for the time of year. I’m happy. Be nice if they had Keeppower cells :wink:
And please stock the fake mustaches :party:
One tested. Charge -> full, then discharge with 1A down to 2.70V with iMax B6:
2443mAh!
:cowboy_hat_face:
Tested the Trustfire 26650:
3907mAh
+1 Definitely would sell like hot cakes. (Who doesn’t like them hot? :D)
Stunning. Thanks for the test!
Awesome! Keep up the good work FastTech! I’ve already ordered a lot of drivers and batteries from you. :cowboy_hat_face:
Cool, Nitecore. Wish I would have waited for my SENS AA… :zipper_mouth_face:
Thanks for testing. Little low isn't it?
-Garry
Perhaps it was first the discharge, so after some cycles it should be same as every time about 4200.
Considering FastTech rates them at 4000, I think it is right on considering variances in testing methods/meters.
At $8.23 each shipped, These are probably the best deal out there in a 26650.
JMHO, YMMV
Thanks,
Keith
any new coupon code from fasttech?
GOTECH is the current coupon code. I just placed my first order with them for 100 7135 chips, magnets, a usb outlet, ipod cord, and headphones. All courtesy of Darkside. :D
Have you seen these?
http://www.fasttech.com/products/1/10001901/1136603-sanyo-18650-2600mah-37v-rechargeable-lithium-batte
http://www.fasttech.com/products/1/10001906/1136802-cree-xm-l-t6-3c-5000k-white-led-emitter-with-20mm-
http://www.fasttech.com/products/1/10001845/1133904-nitecore-mt40-u2-3-mode-860-lumen-led-flashlight
etc etc...
New selection of XM-L LED’s have arrived!!
http://www.fasttech.com/category/1/new-products/LTI9MTItMTctMjAxMg/
Cheers!
Yes, ordered 16mm XM-L T5 5C1 earlier today.
Samsung 2800mAh cells from FastTech measure 2714 mAh (lowest) to 2778 mAh (highest) down to 3V at 1A after being charged to 4.3V. :slight_smile:
Darn, those LED's are cheap! $4.52 for a T6 3C on a 20mm, U2's cheaper still ... The 2mm thickness - not sure, but that sounds real thick for a standard star... Others have them listed as 1.0mm or 1.6mm, gotta wonder if that 2mm is real for the star - need to ask them.
New addtions are great! Prices are awesome. But, we still need U3's and XP-G2's!!
Probably a bit low, can remember what I measured earlier from some other vendor.
I might note that this is the very first cycle…
