I’m in for that…. if the extension tube allows two protected (70mm) batteries.
Yeah, that would be handy
Cheers
Matt
how much does it cost with 9A driver?
No prices were given, only that at least 25 people were needed to put the idea forward.
Cheers
Matt
if it is 9A on one cell (or as close as a good cell will get to that…) definitely
I’d be interested, a king Kong should give 10a, last about half am hour on high though lol, I thought the nine amp driver needed two cells to give the vf for three emitters though, would make the draw on both cells more acceptable.
Certainly stick my name on the list if its less than $100.
Yeah,i think the driver needs 2 cells to operate at 9A
I’m in for 1!
Thanks
As long as it is below 100 dollars then count me in.
would it be more current than regular model on one cell? I think I read 4.5-4.75 amps at the tail in a review…
Hi Matt, will this upgraded driver allow the SL3 to turn on instantly or will it still require the 1 or more seconds to turn on? Thanks.
Ok cheers
The regular model is 4.5A on a single cell. I measured 4.68A on my SL3.
This 9A version might require 2 cells and an extension tube.
MattSPL:Interest check for Shadow SL3 with 9A driver :bigsmile:
This might need to include an extension tube for 2x 26650 use.Hi Matt, will this upgraded driver allow the SL3 to turn on instantly or will it still require the 1 or more seconds to turn on? Thanks.
We will have to wait for Jake25 for some info.
Cheers
Matt
EDIT - sorry, you answered in post 7
i’m a little confused
‘require 2 cells and extension’
does that mean it won’t work w/ one cell?
As far as i know, the 9A driver might require the voltage of 2 cells to operate. Hopefully we will find out more over the next few days.
A 9A version on 1 cell would be a pocket rocket But i’m not sure if its possible, and wouldn’t suit a lot of cells.
possible? sure.
practical…not so much
possible? sure.
I would like the option of being able to use 1 or 2 cells if possible
if it works with one cell, i am in
