Review: UltraFire UF-T1 AAA / 10440 - 2 mode EDC
42 posts / 0 new
old4570
Last seen: 2 weeks 13 min ago
Photobucket
UltraFire UF-T1 Cree R5 2-Mode Mini LED Flashlight - Titanium Texture (AAA/10440)
Price $20.00 + free shipping [ At time of review ]
Description
Model: UltraFire UF-T1
Premium Titanium texture body
LED: Cree R5
Color BIN: White
Total Emitters: 1
Battery Configurations: 1 x AAA/10440 battery (not included)
Switch: Rotatable at its neck
Modes: 2 (Hi/Low)
Lens: Coated Glass Lens
Reflector: Aluminum Smooth/SMO Reflector
Available from Manafont
Disclaimer Light was a private purchase from Manafont
Photobucket
Photobucket
Photobucket
Photobucket
What we have is a very simple , small , functional , light -weight , AAA EDC flashlight that actually performs really well , is well thought out , and executed really well . I must confess to be being impressed by the thought that went into the creation of this light , as it should appeal to a great segment of society , including those in the flashlight community . Now even if this is a clone , then imitation is the greatest form of flattery , and at least some effort went into making it a good one .
I have nothing negative to say , honestly , there is nothing to complain about . Its almost disappointing that there is nothing wrong with this light , because I would have something to write about .
What we have is a 2 mode twisty , that starts in low every time . Low produces some 4L and consumes some 0.06A [ thats 60mAh ] , so if you have a 700mAh battery , that will return some eleven and a half hours of run time , or the proverbial - all night long . High is the second mode and produces some 50L + [ obviously variable depending on battery ] and consumes some 0.4A [ thats 400mAh ] and some one and a half hours on paper - run time .
The way the light has been designed , it should work with almost any battery length . In fact the battery is designed to float in the body , and only make contact at one end when not turned on . When you twist to turn on you are in effect making the internal space smaller until the battery contacts both ends , turning on the light . This is simplicity at its best . No anodizing , not figuring out dimensions , and no critical machining . Just make it to some generous tolerances , and it works , the manufacturer has an easy time of it , and the customer is happy because he or she has a trouble free functioning light that does not spit the dummy at an overly long battery , or a short one perhaps . I do have some AAA that are very short , and the flashlight just by a cats whisker , works with them . You can not put a spring in the tail end as the body is part of the electrical path , if you wished to put in a spring ? It would need to be in the head pushing the battery down into the body . But what would you want to do that ?
I did go for a walk with this light , and as soon as I put it into my pocket it vanished , I could feel nothing . In fact several times I had to tap my pocket just to make sure it was still there , this little light is trully EDC in the finest tradition of EDC. You will see in the picture a place for a lanyard , or Carbiner or something . You could wear it on a belt loop [ carbiner ] or attach it to your key ring , I mean on your key ring you would never be without a flashlight . In fact this one was purchased with the express intention of going on my car keys . I have a small carbiner some where , and this is going to be my Key light .
PWM in low - none in High that I could see
Well centered emitter
Good output for current draw
Well made - clean threads
Nice knurling
Easy to use
Over tightening can make it stop functioning - Dont over tighten
Generous with battery selection
May work with 10440 [ I like this light - so some one else can verify ] I like it plenty with a nimh LSD [ Dont want to Turbo it ]
Photobucket
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: sb56637 on 08/26/2014 - 17:12
_the_
_the_'s picture
Last seen: 4 weeks 1 day ago
Nice review. Thanks for your time!
Do you have DQG to compare this with?
Is it really titanium? What do you think?
=the=
kreisler
kreisler's picture
Last seen: 7 years 4 months ago
Thanks for the review!
What's the exact (+0.001g) weight?
ITP A3 Ti weighs 14.461g Silly
*FMI* i got 4 i/o sh
old4570
11.54g [ grams ]
As for Titanium ? Id have to have  metallurgical  testing done . I have a block of pure Titanium here at home , as to whether this is Titanium , or has a % ?? Sorry guys
What ever it is , it looks to be high grade ...  And damned strong !
Sorry no DQG
djozz
djozz's picture
Last seen: 9 hours 31 min ago
It is a beautifull light, thanks for the review.
Now I indeed need a full comparison to the DQG III , I desperately need an excuse to buy this one as well Smile
BetweenRides
BetweenRides's picture
Last seen: 2 years 9 months ago
That's a beauty - I'm becoming a big fan of bare metal EDC lights. At $20 I seriously doubt this is titanium and Manafont's use of 'texture' in the description sounds a long like 'mimic' used with other items they sell. Price is right too. Thanks for posting, nice review.
djozz
djozz's picture
at cnqg it is claimed to be made of ss
old4570
It could be SS  , I ran a diamond hone over it , and Id say it feels like  stainless steel , sounds like SS when twisting together , but it weighs ?
The weight is Light for SS ... What ever it is - I can live with it
likeaboss
likeaboss's picture
Can you give dimensions?
Candlepower (abbreviated as CP) is a now-obsolete unit which was used to express levels of light intensity.
Candlepowerforums (abbreviated as CPF) a website, also obsolete, drive
Lennart
Lennart's picture
Lennart
old4570
OD = 0.490thou
Length = 2.340thou
old4570
Battery in electric metric calipers is dead , only have imperial dial calipers - Need to order more batteries ..
zecampesien
Last seen: 7 years 11 months ago
Hi folks,
As far as i know, the DQG III is regulated.
What about this clone ? Regulated also or direct drive ?
MRsDNF
MRsDNF's picture
Last seen: 1 week 6 days ago
That's a pretty flash light you have tested. Would it be possible to get a hand shot to put it in perspective size wise for me. I don't have any AAA lights but I'm interested. Cheers.
old4570
djozz
djozz's picture
spooky hand!
The size is as smal as it can be. I find the body of my DQG III a little too thin to my liking, this light looks to be just a bit more robust. And being ultrafire: it is moddable (to XPG2...), the DQG isn't.
Lennart
Lennart's picture
MRsDNF wrote:
That’s a pretty flash light you have tested. Would it be possible to get a hand shot to put it in perspective size wise for me. I don’t have any AAA lights but I’m interested. Cheers.
Compare to a AA battery. Slightly (~3/8”) longer.
Lennart
MRsDNF
MRsDNF's picture
Thanks. That is one tiny light. Now if it was half the price?
NickBose
Last seen: 3 years 6 months ago
Can it be operated with ONE hand easily and reliably?
Speedsix
Last seen: 8 months 1 week ago
What’s the light in the center? The one with the clicky.
NickBose
Stainless steel N-light B3, discontinued, used to be sold by cnqualitygoods
old4570
NickBose wrote:
Speedsix wrote:
What's the light in the center? The one with the clicky.
One handed = Yes
N-Light B3 - Modified - Electronic switch removed and replaced with clicky switch ..  [ reverse clicky ] So much more user friendly ..
Simply one of the best AAA lights ever - at any price .
NickBose
How about battery rattle as in previous DQG?
Does it have a foam ring like the new DQG to hold the battery firmly?
old4570
There is a foam insert in the head but there is slight battery rattle ..
Still something I never noticed over several kilometers of walking over the last 2 days .
Compasillo
Last seen: 7 years 3 months ago
djozz wrote:
spooky hand!
No, it’s not
Compasillo
Length: 59mm
O.D.: 12mm
Weight: 11g
Compasillo
They are prety much the same light. Go ahead and get one UF-T1 (though it’s only in cool white LED and I better like neutral/warm tint)
DQG III, UF-T1
57mm, 59mm
12g, 11g
TIR optics, Reflector (hot spot)
Magnet tail, Better keychain point attachment
1.2-1.5v, 1.2-3.7v (not tested on Li-ion)
djozz
djozz's picture
They are prety much the same light. Go ahead and get one UF-T1 (though it's only in cool white LED and I better like neutral/warm tint) DQG III, UF-T1 57mm, 59mm 12g, 11g TIR optics, Reflector (hot spot) Magnet tail, Better keychain point attachment 1.2-1.5v, 1.2-3.7v (not tested on Li-ion)
Thanks for the extra info, I'll think a bit more about it then...
Stippier
Stippier's picture
Last seen: 1 year 12 months ago
Does anybody who owns this light have problems with it. I had a hard time turning it on and keeping it on. Turn to tight it goes out turn to loose and it also goes out. It had a very small sweet spot for turning it on. And now I can almost not turn it on at all.
AAA: UF-T1, ITP A3 EOS, Tank007 E09
AA/14500: Xeno E03 XM-L T6 NW, Solarstorm SC01, Astrolux S3 (BLF X5), nameless EA41 copy, Ultrafire C3 XR-E Q5
18650: Ultrafire WF-502B XM-L, Ultrafire WF-504B P7, Ultrafire C8, SkyRay King 3x XM-L (gold)
Compasillo
As stated in the OP, overtighten for turning on can make it stop functioning. Your problem sounds like a worn out o-ring…
Stippier
Stippier's picture
I’m not home now but I will try a new O-ring when I’m home. But how can a O-ring have something to do with the electrics?
Btw I have this light form the end of december 2012.
