Not yet, but I plan to install one on mine. I have the XML T6 3C. I will drill and tap the tail cap so I won’t need the nuts. I have switched the driver to a KD V2 6*7135. I like the very low low.
Just put my Fenix TK12 clip on the light. Found a forum where they put an LD20 clip on one but it’s the same clip. Hard part is finding a site that sells the clip.
didnt really understand from intl outdoor site how to change from 3-mode-group to 5-mode group. how should i do it?
and is it normal that modes go in this order: med, high, low?
You are referring to the new version - it uses a different driver, allowing the user to change modes via the UI with no need for soldering. Choice is just 2 modes now, but can be switched on the fly. Haven't done it myself, but what they are saying is switch the light to low, turn it off. When turned on, it will come up in low mode, then in 3 secs it will blink once - very quickly then turn it off then on -- this should change modes. If you don't see the 3 sec blink, you probably have the older EDC driver which is soldered in place.
It means it will blink every single time if I leave in low mode And if I turn it off then, it will go in to strobe mode. Aaaarrrrggg, I hate this. Why can’t they leave a good three mode with memory alone? If they wanted to add the strobe, make it so that it will be almost impossible to accidentally enter in to it e.g. fast click 6 times in 2 seconds or something like that before switching in to strobe mode.
Even though mine had the old 105c driver, I changed it to the KD V2 driver. Mine is set up L-M-H-L-M-H-strobe-SOS with no memory. And it has memory or no memory option. I am thinking about buying another one and will just buy the host and build it like I want.
That’s right about changing from 3 to 5 mode, it doesn’t switch quite that easily. Took me a few tries to get 5 mode, then a few tries again back to 3 mode. It takes 3 quick on/off or something to switch. Dunno, was glad it went back to 3 mode, and it’ll likely stay there. The off/on flash in low mode is a bit surprising/annoying every time, might take getting used to.
I only have 5-6 different lights, this one I’ve had only a week or so, but it’s one of my favorites…. size, brightness, floody…
I bought two of these, one black with XM-L U2, and one gold with XP-G2. They’re very nice. However, the XP-G2 one has had some mode and switch issues ever since it arrived.
Sometimes it’ll turn on and operate normally. Sometimes it’ll blink quickly then turn off, or not turn on at all. Sometimes it’ll turn on and flicker at several different brightnesses without being touched. Sometimes on low it’ll blink off briefly every second or two. And when changing modes with a half-press, it’ll often rotate two or three levels per press, flicker as if shorting, or otherwise behave strangely. It seems like something inside must be cracked or shorting or otherwise damaged.
Any idea if a new switch would help, or is this more likely an issue in some other component?
2. Both of my EDC 18650 lights have PWM on medium and low. However, it flashes so fast I can barely see it. It’s faster than my iTP A3 EOS (final rev), which selfbuilt measured at 2.45 kHz, so I’d guess it’s at least 3 kHz. (and yes, I can see that) It’s much much nicer than the common 200 Hz PWM, and most people probably won’t notice it at all.
4. I added a SolarForce L2 clip to both of mine, and it works great! However, you must add a small spacer in the tailcap to make it contact the non-anodized part of the body. A standard paperclip works pretty well for this, if you can find just the right thickness.
(BTW, the switch/mode issues on one of my units was there before adding a clip; it’s not caused by the spacer)
It still makes a difference in terms of efficiency and beam tint though, as well as how motion looks. I think the only torch I have with true current-regulated constant output is my Zebralight.
If it’s really 4.5 kHz, I’m a little disturbed that I can still see it. That sort of frequency should be heard, not seen…
Efficiency is slightly worse, but no tint shift. I can't see any PWM against computer fan. Do you have older driver with stars or newer 3/5 mode? I have old one.
