Thanks for the macro pictures, I'm guessing it will be harder to dedome. Sadly the days of direct mounting to copper are over, I guess it is time to stock up on some U3s.
If you look at the top of it there aren't any solder pads. This means there is no way to solder it directly to copper (without getting complicated) and still have access to power it up.
I haven’t had time to play with the XML2 yet, but I have a few dozen of them that showed up Friday from mouser… That said, I wouldn’t be surprised if you could solder to the metal under the silicone at the corners/edges…
It does look like that may be the case… It will just depend what material that ‘metal’ is… If, for example, it is aluminum then it will not be possible to solder to it… If it’s plated copper, that would be perfect.
Not sure, but we do have more than a few very capable members for hardware and software development. Perhaps open design (like www.amb.org stuff) where only pcb would be made and sold but users would populate it themselves with readily available parts from RS/farnell/newark/mouser/radioshack…
From what I'm seeing, the buck/boost drivers are more parts, more real estate than the 7135 based designs. This may be fine where you have space in the pill for a 2 PCB design, but won't work on many 1 cell 18650's I've been working on as of late. I'm an independent software devleoper with lots of experience in micros, real-time embedded systems (ASM, C, C++, etc.) and could help with the software though if something can be done - my hardware design experience is near nil though.
