Glenn, I think you will really like it. I just shined the SL3 and the EA4 at the ceiling and the EA4 had a tighter and brighter hot spot.
Well, I’ve decided to pass. My logic is this; I own a pa-40 neutral in the same led bin/tint. The Ea4 neutral is a XML t5…If it were a t6 neutral, I’d buy it already. I’m waiting for a better XML neutral tint. Hopefully the t6 is it….Besides, I own a thrunite tn30 neutral XML t5 as well. Also, I’m waiting for Eagletac’s new light….That’s my story and I’m sticking to it. (as I try my hardest not to buy the ea4)…I will however look forward to my dads response when he receives his ea4 x-mas gift.
Thanks ILIKEflashligts, for putting the throw in perspective.
The EA4 is a T6 3C
I have a G5 Maelstrom that I run with an 18650. I wonder if this light has a bit more spill than the G5 with the extra throw? I believe the G5 is around 12000 lux. Would 2000 mah Eneloop’s work well in it ? Also, won’t the cool white throw a little better than the neutral ? I basically am wondering if it would be a big enough improvement over the G5 to be worth the change.
Thanks
bh46118:Hi Rick
How does it compare in brightness and spill to your SL3.
Thanks Bruce
Bruce,
The EA4 is more of a thrower than alot of spill.
The EA4 destroys the PA40. Not even close.
Here’s the size differences, you can see how small it is!!
Thanks rikr. Now if I could just make one?
Rick, I can't believe how small the Nitecore is! Can't wait to get it!
Here’s beamshots of the PA40, LD40, and the Streamlight ProPoly from selfbuilt
Rick
What are the distances in your beam shots ?
duro:Well, I’ve decided to pass. My logic is this; I own a pa-40 neutral in the same led bin/tint. The Ea4 neutral is a XML t5…If it were a t6 neutral, I’d buy it already. I’m waiting for a better XML neutral tint. Hopefully the t6 is it….Besides, I own a thrunite tn30 neutral XML t5 as well. Also, I’m waiting for Eagletac’s new light….That’s my story and I’m sticking to it. (as I try my hardest not to buy the ea4)…I will however look forward to my dads response when he receives his ea4 x-mas gift.
The EA4 is a T6 3C
Hrm, Craig from Illum. Supply checked with nitecore and they said it’s a T5. Where did you hear it’s a T6?
Rikr, those look like selfbuilt pics. Thanks for the info. I’d like to see a distance shot between the pa40, and your ea4.
Rick
They are 155 feet.
Thanks
bh46118:Rick
They are 155 feet.
flashlight man says that the EA4 kills the PA40 that’s why I found that link to give you an idea on how good of a light this EA4 is…
how does that button feel?
It feels tight not spongy. I dig the blue light on the switch, I think that is such a cool feature!!
That pic of the Pa40 really has some FLOOD…would like to see the EA4 with it in the same framework.
Pulsar:how does that button feel?
You like this little guy dont you?
i do. im going to have to get it on ebay most likely though after xmas. always get $50-100 ebay gift card for xmas, which is going to be this. dont think i have heard one bad thing about it from anyone that bought it
