I was playing with it some more. If you strategically position the led, you can align the reflection of the emitter on the water surface so that it provides a superb aiming target…
Great little gadget!
quickest way to cure a woman complaining about the seat left up?
proceed with seat down.
Hey that’s not a Bud Lite, that’s a Butt Light!
Alas, I had a higher and better use for the Nichia 219. The Nichia 219 piss light is now a Cree XLAMP-7090 piss light.
Glad you’ve got it all shorted out. I’d request beamshots but you might actually post em. (nice thrower!)
Actually, I tried! Butt my camera has problems with the low light level.
Ok, I coaxed an image into the camera. Beamshot added to the fist post. Be careful what you ask for!
Well ain't that a pisser.
OR shaky hand, OR that unexpected side shot :bigsmile:
I hate the unexpected at a time like that.
Why oh why, no matter how much you shake, do the last drops always run down your leg???
… or a submersible toilet light, just throw it in the bowl and go … put it on a string, pull it up … rinse it off… hang it up … tell the missy it’s a night-light …
http://www.amazon.com/Lav-Nav-Motion-Activated-Nightlight/dp/B000G04R76
I like this one because it creates a target in the toilet to piss on.
just got the motion detector i ordered(same as you used)but there is no diagram about input and output wiring,do you remember where to connect input/output?
it does actually require some maintenance. I cut a groove into the rim at the back of the toilet and epoxied a vary large Tritium vial into it. No batteries, no worries.
a photo of the motion detector module
From left to right mine is marked +5V OUT GND. That 102 resistor next to the GND pin is the one that I shorted out to directly drive the LED.
Left left hand pot on the top of the board is TIME. The other is sensitivity. My board does not have those jumpers installed in the corner. I think they are for one-shot/re-triggerable mode.
