How do you like your cheap bike lights? how long does the battery last, is the charger working good? is it ‘good enough’, or would you advice to spend a little more on such lights?
Here are currently active Wallbuys flashlight promotions. I used their coupon code: MERRYCHRISTMAS and got another 5% off, plus a free cheapie gift (several to choose from).
Not sure if the coupon code will work Christmas eve on top of the 50% off…
Probably goes without sayin’, but I plan on putting items on my wishlist, then just checkout when the magical time arrives. Hope this is not like the local auto dealer ads…only one at that price. :~ I reckon if the items are not in stock…then I’m not out anything anyway…’cept a little time.
I have not really put it through the paces, so I cannot say much about battery life or charging. It is very bright, though, as bright as a typical XML light driven near spec. Beam profile is very throwy, so I added a diffuser lens (also shown in the thread I linked) which helps to spread the beam out nicely. I have since purchased the SSC P7 version for $20 from the DX clearance sale. It is essentially identical to the XML version, including accessories and output is pretty much on par with the XML. Again, the beam is very throwy, but I will probably keep it stock since the XML light has the wide angle lens, hence, I'll have nice throw and spill.
