Nice to see that you will give it a go. I can’t wait to see what YOU come up with! There are a couple of different versions of what you ordered, there is no way of knowing until you receive it. The outside dimensions will be the same but what might concern you is whether you get an “inny” or an “outy”
Here is what I mean
The “inny version has smaller plate
Here is an example of an “inny” and an “outy” next to each other. Notice that one is a 120v light, the other is 12V. They both are 12V internally, just a different driver.
I first started getting into these after I read about this: 6 Xm-l light bar build I planned on using several of the 12V lights mounted on the front of my Zero Turn mower, in other words a poor mans light bar.
Maybe these pics will get your creative juices flowing…………
There are a lot of lights out there that beg investigation. Yes, once something gets into the mainstream the price comes down. I can foresee us buying off the self lights just for the parts in the future.
That it is a GREAT source, with CREE led’s and many options on lense angles! I Bookmarked it. My 3 x 3W replacement led’s have shipped from fasttech.com I am disappointed that it took them 5 days just to get the shipment out. Not very fast so far!
BTW, I ordered a pogoplug off buy.com yesterday morning and it is already at my post office this morning!
Point is that they got it in the mail the same day, not 5 days later.
I got mine in the mail yesterday. I wired each emitter in parallel and put it back together. I direct drove it on an 18650. I checked the current and its only pulling .33a! I’m going to drop it in my 3d mag tonight and see what it does. Not very impressed so far but its for a nightstand light that never leaves the bedroom. I wonder how much current these led’s can handle?
Something is not right, you should get about 1A
BTW, I ordered and replaced the 3 1W LED’s with 3W cool white ones and now get over 2 amps draw and brightness about equal to my P7 drop in.
I got my bulb and it was an "inny" top plate. That's ok, I just incorporated the whole housing into the build. I got the 3w leds, so it's 9w total. I haven't finished the build yet, but I made a copper plug on the underside of the housing, to make it flush and an aluminum heat sink in the body tube, that the housing attaches to (now). It is bright and close to an SSC P7 in brightness and profile. Mine is cool white, but it's a "little too cool" for me, LOL.
Thanks to dchomak for starting this thread. After the holidays, I will post a build thread on mine. It's not XM-L territory, but it is a respectable amount of light at a very reasonable price. Easy build for a Maglite.
Well, it depends on what you want. If you want some throw (not a lot), then 30 degree. The tightest they offer. If you want flood, then 45 degree. If you want a mule, then 120 degree. The larger the degree number, the wider the beam, but I do not feel they are necessarily a direct correlation from stated degree to actual beam degree, from the ones I have tried.
Yeah, something wasn’t right. The 18650 I used was only showing 3.4v on my dmm. I got another 18650 that showed 3.8v (and pulled 2a on my dmm) and tried that. It lit up my backyard! I pulled a fresh one off the charger that was 4.2v and the module was back to barely putting out any light. I then noticed that only one emitter was working. I think the other two got burned up. And I can’t figure out why my dmm was showing such a high amperage.
A gotcha on this light is the possibility of a poor thermal contact between the individual emitters and the star, and/or poor thermal contact between the star and the sink. These emitters were originally running on 12V in series or 4V each. I wouldn’t think 4.2 would be too high. I run mine on 3 Ni-MH or about 3.6-4V
The good news is now you have an excuse to install these:
Well, from what I can tell, the leds are bridgelux, not cree and they could be 3w bridgelux, but I don’t know for sure. (they could simply be generic Chinese leds too). No markings that I can see. Once it’s powered I can see what I get for amp draw and maybe go from there. It will be DD with 3 Eneloops. From what I saw with the initial checks, with 3 Alkalines, it was about as bright as what I remember of the old P7 lights I used to build. I won’t be finishing anything till after the first of the year though. This one and the 3-XM-L in a Mag LED reflector…
I bought some of those LED’s from fasttech last night. I find it hard to believe that I fried the ones that were on the star so quickly. I only had them burning for approximately 2 seconds before disconnecting them. How can I test them to see if they blew?
The ones you ordered, the ones I have now are rated at
Operating Voltage 3.0-3.8 -volt
We already know that you saw huge difference between 3.4V and 3.8 volts on your 1W leds. So to go from 3.8V to 4.2 is maybe too much for direct drive. What do you plan to use for a cell or cells? I am using 3-D cells, Ni-MH which give me 4V open circuit. I get a 2.15A on the draw, but these are the 3W BridgeLux leds.
When you solder the new leds onto the star make sure you use a thermal adhesive between first, then solder the leads. If the led is not sinked to the star, it will over heat very quickly. 2A through those 3-1W leds is too much, probably due to over voltage. 4.2 is too high
here are some beam shots
the control, just a 130W equivalent CFL in the lamp post
now a P7 drop in driven by 4- C Cell NiCads in a mag 3D
Then get a bulb from a Maglite, smash the glass and attach the above LED, maybe with some improvised heat sinking. maybe filling the bulb with solder etc, and run it DD?
Or simply make something that resembles the metal part of the bulb. I am thinking, no mods drop it in like the terralux drop-ins.
Yes, please! Directions would be most helpful too. What parts did you need to remove from the switch? I follow directions pretty good, but figuring it out? Not this year, or any other. Very neat mod.
Thanx;
C.
:quest: O.K., I think I got it…Starting from the lower left LED, (the one closest to the solder blob labeled + , which appears to be attached to the + of the LL LED by a trace) run wires and solder the + terminals of the other LEDs, going counter-clockwise, to the blob of solder labeled +.) Do the same for the - terminals. Is that it? What must you do to keep from desoldering the original connections? I doubt my Weller 2 speed 100- 200 watt solder gun would be the proper tool, right? What gauge wire is best?
