no worries! Looking forward to the finished light
Still eagerly waiting for that driver.
But in the meantime I did got parts for switch and would like to share some pics and info about that.
Here’s parts that I bought
(ABS-10 host , 59P switch , 3mm led , PU5x0,25 cable , DA40 grommet and some velcro strap )
After making button hole little bigger and holes for starp ( also did put some silicone inside, so it’s waterproof ) - here’s finished switch.
neat remote, I like how you put the stat led next to the switch. It’s always good to see different approaches to remotes. I’m going to try and incorporate my next one into the brake lever clamp to reduce the reach, not quite sure how yet.
Thanks!
It’s fun to watch work of different people. All of us think individually, so you get good ideas from others
Mounting to brake lever is good idea. Would love see how you make it.
Can I just say, this is an awesome project. Keep us updated.
I’ll let you know as soon as I figure it out myself
Thank you gords1001! I’m liking this project also.
matthemuppet: That would be awesome!
Okay, so I did get that awesome taskled b3flex driver on friday. Was very psyched to continue with this project.
I measured correct places for leds on pill and put those together with adhesive
Then on otherside of pill I soldered led wires to driver
So far everything was perfect. Then I soldered all other wires to driver and fastened it to body. Tested it with 4S1P battery pack. IT SHINES!!
Light started up nicely. After little configuration for driver everyting was setup for this light. When I had been playing with light for a while i noticed that it does not go OFF correctly, two out off three leds had some “moonlight” dim going on while light should have been off. So there had to be same leak to body that this could happen. At this point I should just have let it be like that, since it was pretty minor. BUT I want to make everything work perfectly, so I opened light again. I did found out that while I fastened the pill there was wires that contacted the body. I should have done pill little differently, but I did not want to make that again. So I started to make little modifications to … hmm … everything. After many bad decisions, too many hours, too little food and one angry wife later this is what happened
So I as you can imagine the light won’t start up again. I spoiled driver. Luckily driver was only one that got destroyed in this mess. Basicly everything gone to hell with this project in past two days.
Well… there is really nothing more to do now than clean up, learn from mistakes and order new driver. Atleast now I know what I should do and what I should not do (If you want to try find some good things about this). :~
Not my weekend.
BUUT tomorrow is new years eve and it’s time to relax. I wish all fellow members a very good new year!
I love it! You need a trash can right next to the table. I have a trash can about 15’ away, so I can do basketball shots into it, with my mistakes!
It really is a beautiful build and I know you will come back to show it off when it's done. It looks like you are doing well and as you say, learn from your mistakes, so it should be ab awesome light!
Thanks OL!
Trash can sure would be handy and throwing basketball shots to it would also cheer mind up
Bugger. It comes back to the old saying that if something can go wrong it will. Tomorrow is always a new day that brings a clear head and with any luck a happier wife. To you as well have a happy new year and looking forward to the next chapter in this amazing lght. Cheers.
Great machining skills! How did you polish the parts?
Thanks! That saying seems to be very true. It’s a new day now with clear head and new plans for how to implant that driver ( happy wife also :).
Thanks!
I used 800&2000 sand papers. After that I used two types of waxes with leather to get finishing polish.
Parts that I made in lathe - I also polished in lathe.
Really nice work. George at Taskled makes very good drivers but it takes a lot of patience to cycle through 13 different programming modes. Nice that you can set low voltage warnings at different levels using different battery setups. Thank you for posting set backs as well as successes. That’s the way modding can be with a first time build. Looking forward to your results.
Thanks! Yea, those are really nice drivers. It makes light much much more usable. Set backs are my way of learning things :).
Great work man! That truly is mirror finish!
kahvitahra, that looks really sweet…. i wonder how does your bike look like….
Hehe, Thanks man! Currently I only own city bike, so nothing fancy there
Hi again!
So, I finished my battery pack this week. As I said earlier it’s powered by 4S2P 18650 3100mAh batteries.
Here’s parts that i worked with ( also some wires, heatclue & wood sticks between batteries )
After cluing and soldering batteries together, adding balance and power lead, this is how it looked like.
I was a little afraid of heating that shrink shock on top of that pack. I’m sure batteries heated over 100C while doing this. Those big shrink shocks ( with clue ) takes massive amount of heat and it takes some time to cool off. But “luckily” nothing exploded and I did get ROCK SOLID battery pack.
After it was completed I went to local store to find right size and cheap camera pouch on top of pack. That pouch has velcro strap also, so I can easily mount it to bicycle bar.
You are better to have a 4S protection board build-in the battery pack.
