That it is a GREAT source, with CREE led’s and many options on lense angles! I Bookmarked it. My 3 x 3W replacement led’s have shipped from fasttech.com I am disappointed that it took them 5 days just to get the shipment out. Not very fast so far!
BTW, I ordered a pogoplug off buy.com yesterday morning and it is already at my post office this morning!
Point is that they got it in the mail the same day, not 5 days later.
I got mine in the mail yesterday. I wired each emitter in parallel and put it back together. I direct drove it on an 18650. I checked the current and its only pulling .33a! I’m going to drop it in my 3d mag tonight and see what it does. Not very impressed so far but its for a nightstand light that never leaves the bedroom. I wonder how much current these led’s can handle?
Something is not right, you should get about 1A
BTW, I ordered and replaced the 3 1W LED’s with 3W cool white ones and now get over 2 amps draw and brightness about equal to my P7 drop in.
I got my bulb and it was an "inny" top plate. That's ok, I just incorporated the whole housing into the build. I got the 3w leds, so it's 9w total. I haven't finished the build yet, but I made a copper plug on the underside of the housing, to make it flush and an aluminum heat sink in the body tube, that the housing attaches to (now). It is bright and close to an SSC P7 in brightness and profile. Mine is cool white, but it's a "little too cool" for me, LOL.
Thanks to dchomak for starting this thread. After the holidays, I will post a build thread on mine. It's not XM-L territory, but it is a respectable amount of light at a very reasonable price. Easy build for a Maglite.
Well, it depends on what you want. If you want some throw (not a lot), then 30 degree. The tightest they offer. If you want flood, then 45 degree. If you want a mule, then 120 degree. The larger the degree number, the wider the beam, but I do not feel they are necessarily a direct correlation from stated degree to actual beam degree, from the ones I have tried.
Yeah, something wasn’t right. The 18650 I used was only showing 3.4v on my dmm. I got another 18650 that showed 3.8v (and pulled 2a on my dmm) and tried that. It lit up my backyard! I pulled a fresh one off the charger that was 4.2v and the module was back to barely putting out any light. I then noticed that only one emitter was working. I think the other two got burned up. And I can’t figure out why my dmm was showing such a high amperage.
A gotcha on this light is the possibility of a poor thermal contact between the individual emitters and the star, and/or poor thermal contact between the star and the sink. These emitters were originally running on 12V in series or 4V each. I wouldn’t think 4.2 would be too high. I run mine on 3 Ni-MH or about 3.6-4V
The good news is now you have an excuse to install these:
Well, from what I can tell, the leds are bridgelux, not cree and they could be 3w bridgelux, but I don’t know for sure. (they could simply be generic Chinese leds too). No markings that I can see. Once it’s powered I can see what I get for amp draw and maybe go from there. It will be DD with 3 Eneloops. From what I saw with the initial checks, with 3 Alkalines, it was about as bright as what I remember of the old P7 lights I used to build. I won’t be finishing anything till after the first of the year though. This one and the 3-XM-L in a Mag LED reflector…
I bought some of those LED’s from fasttech last night. I find it hard to believe that I fried the ones that were on the star so quickly. I only had them burning for approximately 2 seconds before disconnecting them. How can I test them to see if they blew?
The ones you ordered, the ones I have now are rated at
Operating Voltage 3.0-3.8 -volt
We already know that you saw huge difference between 3.4V and 3.8 volts on your 1W leds. So to go from 3.8V to 4.2 is maybe too much for direct drive. What do you plan to use for a cell or cells? I am using 3-D cells, Ni-MH which give me 4V open circuit. I get a 2.15A on the draw, but these are the 3W BridgeLux leds.
When you solder the new leds onto the star make sure you use a thermal adhesive between first, then solder the leads. If the led is not sinked to the star, it will over heat very quickly. 2A through those 3-1W leds is too much, probably due to over voltage. 4.2 is too high
here are some beam shots
the control, just a 130W equivalent CFL in the lamp post
now a P7 drop in driven by 4- C Cell NiCads in a mag 3D
Then get a bulb from a Maglite, smash the glass and attach the above LED, maybe with some improvised heat sinking. maybe filling the bulb with solder etc, and run it DD?
Or simply make something that resembles the metal part of the bulb. I am thinking, no mods drop it in like the terralux drop-ins.
Yes, please! Directions would be most helpful too. What parts did you need to remove from the switch? I follow directions pretty good, but figuring it out? Not this year, or any other. Very neat mod.
Thanx;
C.
:quest: O.K., I think I got it…Starting from the lower left LED, (the one closest to the solder blob labeled + , which appears to be attached to the + of the LL LED by a trace) run wires and solder the + terminals of the other LEDs, going counter-clockwise, to the blob of solder labeled +.) Do the same for the - terminals. Is that it? What must you do to keep from desoldering the original connections? I doubt my Weller 2 speed 100- 200 watt solder gun would be the proper tool, right? What gauge wire is best?
Here is another pic and where the changes need to be made
drill or cut where the blue lines point to.
solder the + wires to the locations in red
solder the - wires to the locations in black
Things to be careful of:
If you don’t drill all the way thru, as I did, make sure that the side opposite the drilling doesn’t become dimpled as that bump will cause poor contact between the star and the sink.
After the drilling (or cutting) be sure there is no short to the star.
When you solder the LEDs make sure the led does not lift of the star, the base of the led needs to have good thermal contact with the star. (The second one of these that I made I re-flowed it right onto the pad)
When you put it back together make sure after you put the lenses back in and screw down the face plate there is no rattling in the light, if hear anything loose you need to be sure the lenses a centered correctly in the faceplate.
Good Luck!
The second one I made has the 3W each white LED’s (really 2W) and I used a 2C Mag host. 2 C Cells is not enough voltage but a single 18650 is. Works great.
Your going to have a blast combing the isle ways at HD and Lowe's when they run sales. Lots a valuable parts can be found and/or modded for special use... whole new world
i’m planning on doing this mod as well! i’ve already got a cool white led bulb, and awaiting a warm white led buld, and some time, and a good/unexpected host for it…
