Your new years first up build is to build this flashlight so that dummys like me can learn how the aa batteries work in whatever configuration and how to make the switch work with what ever driver you deem that will make it all work. No pressure, you are the nMh king. Thanks in advance.
I see my EA4 is on the truck for delivery today. If I knew it was coming I would have done a complete analysis and break in for my XXXEneloops, but that takes two days.
I have ordered from IlluminationSupply at December 13 and shipped December 14, received today 21, 7 days from California to Istanbul.
It is faster then I expected. There is direct flights from LA to Istanbul. May be USPS using one of them.
It’s UI needs getting used to.
I have the NW version. Tried with alkalines, and and also eneloops.
It is very good, compact and with a good throw.
Can not managed to unlock from lockout mode.
The manual says:
To exit lockout mode, simply press three times within a second.
I have tried several times, but I could not unlock, so I have released batteries to unlock.
Just tried instead of pressing three times, I just pressed still about 2-3 seconds. it has unlocked.
It’s basically a process of totally draining and recharging them. It’s good to do with new cells, or ones that have been sitting idle for a while. You might say that it gets their juices flowing. NiMh actually improve in performance after they’ve been drained and recharged a few times.
I missed my parcel today. I’ll have to pick it up tomorrow. I’m going to give my cells a break in right now. I also use a Maha C9000.
It is, but it still is a good idea of what the EA4 can do. It lights up the trees and the hill pretty good in person. Just not as intense. Great light!
That’s what happens when you take pictures in auto exposure with a very long shutter speed. Manual exposure with a 1.2 sec shutter would reduce that photo above by I would say 75%.
75%, not a chance. You would not even be able to see anything. Like I said before it is just a bit more intense. Look at the pics rikr first posted. This thing is a beast.
I have been to Rick’s place and know how far those pictures are approx. Those trees you have lit up are way off like how far did you say they were. There ain’t no way in hell that a light that throws less than the TK35 is even going to come close to doing that to those trees in the distance. I know. I have a TK35. I also know what taking pictures will do to a beam with long shutter speeds of much over 1.2 sec. Go take that same photo on the settings I posted and turn white balance to fine. Use a focal of 4 and put your ISO on 400 and then get back with me on your results. My bet is you will do good to see the beam on the trees much at all and nowhere near what your trying to insinuate in that photo above.
And get rid of the embedded photo file format so people can see what your camera settings are truly are. Heck on mine you can go find out all my details of the camera info.
Case in point below of a TK35 beam at 110yds on the setting I told you about above.
