Not sure, but we do have more than a few very capable members for hardware and software development. Perhaps open design (like www.amb.org stuff) where only pcb would be made and sold but users would populate it themselves with readily available parts from RS/farnell/newark/mouser/radioshack…
From what I'm seeing, the buck/boost drivers are more parts, more real estate than the 7135 based designs. This may be fine where you have space in the pill for a 2 PCB design, but won't work on many 1 cell 18650's I've been working on as of late. I'm an independent software devleoper with lots of experience in micros, real-time embedded systems (ASM, C, C++, etc.) and could help with the software though if something can be done - my hardware design experience is near nil though.
Well “standard” 17mm board is quite small and I’m pretty certain that buck/boost driver is not an option but simple buck driver governed by attiny family ic could be feasible. Perhaps even some software code from luxdrv/blfvd could be used.
PilotPTK was in the process of designing a 17mm buck driver which looked fantastic and was supposed to have only a 0.5V overhead - hopefully we’ll hear more after the holidays.
Looks like I’ll be getting some stars and XM-L2s to reflow onto them, can’t wait to try these out in a new bike light. T6 5000K 3C (hopefully) with the same output but better CRI as my current U2 CW equipped light.
I'm still waitin on my Mouser order of 3, shipped Monday, maybe in today. Planning on reflowing onto existing star boards in a couple of my better lights.
Awesome!!! Looking forward to all your results fellas!
Is there a "category" for XML2 on mouser.com? I find their site very unclear..
This is the item page I ordered: mouser XMLBWT-02-0000-000LT60E3. Hope this helps. Down to 142 in stock.
Now if we only knew the exact tint.. :D
He, he, down to 140…
How long until a p60 dropin? :nerd_face:
I am guessing 3C or close to it.
Does the XML2 emitter fit on regular XML MPCB’s? I wonder when will Intl Outdoor be stocking these?
Now if we only knew the exact tint…
We do… sort of.
The last three numbers in the product code are the chromaticity, and it’s an “E3 KIT”. Which means they will be one of four 5000k region.
Either 3A, 3B, 3C, or 3D. — Luck of the draw which one.
Any would be okay with me.
The XM-L2 document refers to the XM-L document for chromaticity, and here’s where I found the information on page 10:
—— EDIT ——
It’s also an XM-L2 T6 bin, which should be pretty much identical in brightness to an XM-L U3 bin. (But this one is a NW!)
Ohhhhh!!! I just found two more XM-L2 options they have IN STOCK!!!
XM-L2 T5 (same approximate brightness as an XM-L U2)
Chromaticity kit 51… which unfortunately means it could be any of these cool-neutral white possibilities: 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S
Spin the wheel of binfortune!
XM-L2 T2
(same approximate brightness as an XM-L T4)
Chromaticity kit E8… which means it could be any of these warm white possibilities: 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4
They have a whole bunch of others listed as on order, so we’ll have to watch and see as they show up…
From what I’m seeing, the buck/boost drivers are more parts, more real estate than the 7135 based designs.
Probably important to remember that the 7135 option provides zero boost capability. Buck/boost would be awesome if harder and more expensive. A straight buck should be able to gain efficiency while providing similar capabilities.
When these are more prevalent, I am definitely ordering a pile of them.
