My Nitecore EA4
Rick, do not argue with Brad, it's not worth it! lol!
P.S. Brad, you're ok in my book :)
Rick,
Water under the bridge buddy. :wink:
I love it! I finally got my neutral EA4 and it is amazing. This thing illuminates everything with lots of horsepower down the middle. The 3C tint is very nice, although I wish it was 4C. Pay no attention to me, the 3C is real nice. I never even knew what a tint snob was until I joined this forum, and now I are one.
Compact. Powerful. Uses AA. I nominate the EA4 “Flashlight of the year”.
Sounds good :slight_smile:
Interested to see a comparison between CW and Neutral in the EA4 if anybody has any shots.
Cheers
Matt
Shhhhhhhhh! We’re trying not to mention the “beamshot” word.
:smiley: ooops, sorry, i forgot about that :bigsmile:
+1 “I nominate the EA4 ”Flashlight of the year” It’s an amazing light!!
Okay. I had four Imedions in the charger doing a complete break in, and they weren’t ready yet, so I grabbed four Eneloop. I didn’t bother to test them , I just threw them in.
After playing with my EA4 for a while off my balcony, mostly on turbo, I noticed the low voltage indicator doing a constant flash. When switching over to the other modes the indicator stopped flashing, but would begin again when I went to turbo. I tested the eneloops under load with my ZTS and showed 60%.
This is good to know. Turbo reminding you that it’s sucking juice, while there is still ample reserve in lower modes.
The voltage indicator that is enabled after you perform the lockout steps gave me five flashes. That indicates Five volts, which makes no sense to me, unless they weren’t long flashes, but short, which would indicate .5 volts. I’ll have to wait for fresh cells and a darker room to try this again. It seems to be the same system used on my EC2 except with AA.
My eyes are kind of dim, so if anyone else wants to give a test of their voltage reading, let me know the outcome.
Yes, they were actually five short flashes which indicate .5V. If it had given me one long and two short it would have indicated 1.2V. I’ve never had a multi AA in series light before so I am curious as to what the starting voltage will be with fresh cells. My Imedions should be ready in the morning, so I’ll do a test while having my morning coffee.
Seriously the x-ml is a beast. I absolutely love this emitter :smiley:
I was wrong. There are no long flashes. I tried again with fully charged cells, and this is what I got; five short flashes and a pause, then seven more short flashes. I assume this would indicate 5.7V. I kinda like the long and short system used on the EC2 better.
Just got mine and noticed an uneven gap between the body and the bezel. Anyone else notice that? I hope it wasn't cross threaded at the factory. Other than that, this thing is awesome. Can't wait to check it out tonight.
One other thing, there's a rattle coming from the head when I shake it. Seems to be common according to what I've read on cpf..
Glenn,
Mine looks just like yours, I had never noticed that before. You really have to look for it to see it.
Mine has a gap too but it is even all around.
Rick, I noticed it right away. As long as it's not cross-threaded and watertight, I'll be ok with it. I'm kind of afraid to test it for water tightness though. Does yours have a slight rattle when you shake it?
Yep, never noticed that either. You really have to shake it to hear it…
I wonder if its affected by battery brand?
Sounds like a non issue if it takes vigorous shaking to hear it.
Mine doesn't take much to make it rattle. Not a biggie really. From what I've read it's pretty common, and it varies from sample to sample
I inspected mine and I don’t see anything like that. There is a slight gap all around the bezel ring, but that’s normal. I shook mine up a bit, and no rattle at all.
It’s a bit like déjà vu though. I’m sure I read in a thread somewhere with members having the same rattle, although I’m not sure it’s the same light. I can’t remember if they had to tighten it down, or loosen it up to get rid of the rattle.
I wonder if its a batch thing. Where did you guys purchase yours from? I got mine from Intl-Outdoor.
