Balder TD-0
Overall Rating: ★★★★★
Summary:
Battery: | 1 x AAA or 1 x 10440 |
Switch: | Head twist |
Modes: | High, Mid, Low |
LED Type: | CREE XP-G R5 |
Lens: | Coated Glass |
Tailstands: | No |
Price Payed: | $25.99 |
Date Ordered: | 19 November 12 |
Pros:
- Very high quality
- Bright
- 1 lumen low
- Titanium glass breaker
- Waterproof
- Spare O-rings
Cons:
- Some PWM on med and low modes (only visible on camera)
Features / Value: ★★★★★ 4.5/5
The Balder TD-0 comes in a small plastic pull apart box, in the box along with the flashlight itself is a user manual and 2 o-rings.
It would've been nicer to see a proper box to make this more suitable for gifting. I'd gift it anyway, just because of how nice the torch is.
At the rear of the TD-0 we have a Titanium glass breaker, I have yet to test it on anything but this would be a good thing to have if you are ever trapped in a car. There is also a spot to attach a lanyard or key chain, it seems to be removable with some force if you don't like it there.
Pricing is a little expensive, but I think it is worth every cent for this specimen.
Design / Build Quality: ★★★★★
Here we have a shot of the SolarForce X2, Balder TD-0, SolarForce X3 and Nitecore T2s from left to right. You can see that the Balder TD-0 is a little thicker than the other AAA flashlights, this is due to a different design for the twist switch. It is still significantly thinner than a AA flashlight.
The TD-0 has the head screw over the body unlike other AAA twisty lights which have the head screw into the body. This is what makes the TD-0 slightly thicker than other lights.
This design has allowed Balder to anodize the thread of the body and only leave electrical contact at the top of the body. This prevents the TD-0 from switch on unless the head is screwed all the way down onto the body. Balder has also used a spring at the end of the body for the battery. This method of design works very well, the flashlight has a defined on/off position. It also helps that the threads are very well greased so it is smooooth.
I like the design on the body of the torch, its quite stylish and doesn't get in the way of using the flashlight.
The Balder TD-0 has a 2 part head, this seems to be very rare in AAA flashlights. This allows for easier modding. Everything seems to very clean in the TD-0.
If you get this torch, make sure to tighten this part of the light, otherwise you may end up loosening it when turning the light on. I use the upper part of the head to turn on/off the light because there is no knurling on the pill/lower head.
Everything looks like its aluminium apart from the titanium glass breaker and lanyard ring. There are 2 o-rings in total, around both the openings.
The TD-0 is available in a few colours, black, titanium grey (what I got), sand yellow and dark green. I cannot find where to buy the dark green colour, but it exists. CNQG says its 40g, its actually much lower at somewhere between 15g-18g (feels just over half of the X3's weight)
Because of Balder's design, I cannot measure the amps. Sorry. Got the amps drawn. High: 1.67a Med: 0.60a Low: 0.12a
Battery Life: ★★★★★
It has a high brightness for when you need it and a 1 lumen low for a very long battery life.
Light Output: ★★★★★
Brightness on AAA is very good, I don't have a 10440 to try but it should be even brighter. Low mode is good for when you need something to get around the house at night without disturbing anyone or to use in the car at night without blinding yourself from the light reflecting. The XPG-G R5 does an excellent job in the Balder TD-0
Summary:
A flashlight that is a little pricey for being so small, but does a very good job at what its made for. Superb build quality and very smooth operation of the twisty switch. The TD-0 feels good in your hand, the slightly bigger size and weight isn't a deal breaker at all. It makes a great EDC if you need something small, with a range of colours to choose from you can get the one you like. This is my current EDC, it has beaten the SolarForce X3 and Nitecore T2s to gain its position.
Highly recommended buy. Thank you for reading.
