My Nitecore EA4
I agree I wouldn’t take a chance scratching it up. Just sucks you have to go through this.
The threads weren’t cut concentric to the aluminum head. In other words the aluminum head has to be put in a professional grade cutting/boring machince and on what we used to call a fixture to lay the part on. The part or in this case piece of aluminum is then clamped down to hold it to where it can’t move. The threads are then cut by probably a carbide insert and have to be cut in parallel to the piece of aluminum. That is what concentricity is. That wasn’t done here apparently on a lot of these EA4’s.
I use to work at Dana Corp and machined and assembled differential cases. When we machined the case for the sidegear dimensions, and the machine was set up correctly it would cut top and bottom sidegear concentricity dimensions to under .0005 total runout for each sidegear throat. That’s almost as accurate as drilling a hole for true roundness with a very expensive professional drill bit.
my ea4 has a poltergeist… seriously… i shook the living hell out of it last night to see if it rattled…and nothing…. now i picked it up tonight and i heard a small noise… so i shook it gently and i heard a little rattle from behind the switch …
DAFAQ?
its not that bad - i dont mind living with it since it doesnt really effect anything and i dont go around shaking the crap out of my lights.
if anyone asks me what the rattling noise coming from my flashlight ill just tell them its the flux capacitor
Fair enough mate. Sorry i misunderstood you
If you get the end of a leather belt around the bezel, then grip the belt/bezel in one hand and body of the light in the other, you should be able to undo it.
I did this with my olight s10 and it worked nicely.
I'm sure that would work but Craig's sending me a replacement. I don't want to mess with this one. Thanks for the helpful info though :)
Sorry if this questions has been asked and answered already, but how does it compare to C8?
Hows the throw compared to C8?
another good trick is to use the bottom of your shoe - the rubber bottom grips the bezels without damaging them.
Craig
Mine has the rattle issue, the bezel has no problem, it has an even gap.
I have it from Illumination Supply.
Craig said it may be a loose screw inside.
What is the proper tool to unscrew the bezel?
I have tried shoe rubber, not worked for me.
My NW rattles to beat hell, the CW has no rattle at all. :frowning: :slight_smile:
I took apart a few EA4s which have the rattling problem.
The culprit is the white delrin ring
I’m not entirely sure as to the purpose of the ring (other than to fill up the empty space in the light, but some are ever so slightly thinner than others, and cause the rattle. This does not change the reliability of the light at all.
Craig
Man, he beat me by 2 minutes. :wink: I guess I was right on my findings.
I was wondering why the title suddenly changed! :slight_smile:
Craig
whats it, go around the bottom part of the reflector to keep it centered?
yes, it’s right below the reflector. However, due to the size of the reflector keeping the reflector in place
and the centering ring around the LED, this seems like a bit of overengineering on Nitecore’s part.
which bit them in the backside, lol.
Craig
Good to know it's not going to cause problems down the road. Now if they can just screw the damn bezel on straight, I'd be tickled pink. lol!
Hi Craig
How much extra run time would the 2700mah powerex offer vs the 2000mah eneloop ?
Thanks Bruce
Is rattle demon free. Hope that those who do have the rattle can resolve the issue.
Looks like the rattle can easily be fixed with a couple of small dabs of silicone sealer
I didn’t bother putting anything on mine, it don’t rattle hardly at all. Wish I knew Craig was going to take one apart… now I know whats in there… :slight_smile:
