i will definitely take up the challenge… but i doubt it very much it will reach 300 yards… but i’m pretty sure it can throw a lot father than 80’
i wish there’s more people take this challenge and prove it to themselves.
if you don’t have trustfire WF 502B… use any flood light even those that using AA or AAA batteries to see it how much farther it can shoot.
but as far more pictures regarding the shot it will be pointless for me now, as the only camera i have is point and shoot camera.
like scaru said… the point and shoot camera isn’t always take a consistent picture.
and i’m not gonna buy a very expensive camera so i can justify this theory.
using the thrower flashlight for beam shot comparison is just unjustified, as i found out throwier reflector need longer distance between the magnifying glass and the flashlight, in order to achive a tighter beam.
using flooder light is the best way to test this theory
Yes, but this has been disproven two ways now. 1st, by using a a camera with standardized settings. 2nd, by using science. I just don't get what is so confusing.
I just went outside with my L2P and a huge lens.. despite the ability of projecting a die image, there was no surprise. Ugly beam with a huge hole in the middle, significantly less light overall and less light in the hotspot. If the light in the hotspot had stayed the same, I would agree with the theory of "more throw" (although it would just be an optical trick, like aspheric throwers, more contrast and so on..). But it didnt.
Oh come on NZ, you got to be kidding us. How many times have we said now that these shots are misleading? Just look at the outer parts of the image, where the flashlight doesnt shine.. one is lighter than the other. Different exposure and aperture obviously.
It definitely would not, I mean a Lumatic 3 dollars AAA light has a focused hotspot and my L2 doesn't. Guess which one throws further?
And as nightcrawl pointed out, the exposure is drastically different. Look at the wall on the edge of the picture. In one it is lit up, and in the other it isn't. That is a sure sign of a different exposure.
In other words the needle beam of a laser really gets out there. So I’m guessing his logic here is that maybe the narrower the flashlight beam the more it should logically act like a needle beam laser and really get out there further shining into a concentrated spot than if the same laser had a much wider beam and you could barely see where it was illuminating the same specific object out in the distance.
I’m just trying to imagine what he’s thinking here.
Looks like NZ may have finally realized he's wrong. :D If you're so sure of yourself come discuss, prove your points instead of regurgitating what you already said. I know I'm right so I will stay and discuss.
I understand your view point, but unlike politics there is one correct answer. My flashlight with the lens had the same type of beam, laser like. But the difference is both of mine were exposed equally so it showed it was weaker. His camera was trying to make them look the same, so it increased the shutter speed on the second picture.
yes i was using this Celestron 70mm telescope as it is easier to hold while i shoot the picture.
the telescope is about the same length as the build… around 12”–14” almost the same diameter 3’5 and 4” respectively
have you ever seen or have a telescope before? just in case you didn’t know… the one that magnify the light( to see the object closer ) it came from the eyepieces not from the telescope itself…
the front of the telescope is almost identical to that 2X magnifying glasses but for sure it’s not a dual aspheric lenses.
it seems we’re forgetting something here… this is not a mod to the flashlight itself to make it brighter, but as a fun built as to make the flashlight more throwier.
as OL said… scientifically it will not make it brighter… but as far as the eyes can see… it appear to be so.
if it can shoot farther than what i have before… then that’s what’s matter over here
I think we also have a problem with the definition of throw.. throw is how far you can still get measure 0.25lux (thats about moonlight). But perceived throw is another story.. its a matter of contrast. A small hotspot will look like more throw than a large one, even if the large one is a brighter by a certain amount.
You cant really compare that. You can make a tighter beam with a lot of utilities, even by blocking 90% of the light. Would that be a better thrower then?
