DL, why are you so determined that you don't want to learn about the correct terminology? Imagine you wanted to discuss car motors and someone would constantly confuse horsepower and torque... At some point, you'll not only confuse members, you'll irritate them.
DayLighter I’m with you. Many here has not read (or understood) what I pointed at in post #24.
Not that it is easy stuff, It took me years to comprehend it (I was ten years in an optical lab as a software developer).
What you did was to focus the beam better and as a result you have a brighter hotspot as you say. Simple as that.
Brightness has little to do with total output and is a physiological, unlinear unit. Just as you say, does this look brighter than that?
Think of this experiment: You light up a wall with your light and have a bright hotspot on the wall. You take a dark cloth to the wall and block half of the hotspot.
The result is that the remaining hotspot has exactly the same brightness as before althougt you blocked half of the lumens out.
Brightness is an unlinear function of an objects Luminance. The Luminance of the object (here the hotspot on the wall) is the difficult thing to understand. It is measured in candela per square metre.
Bicycle lights are often measured in Candelas (which is lumens per unit of solid angle - Half a sphere covers about 6 units of solid angle).
Think of the hotspot as a collection of houndreds of tiny bicycle lights that shine in your face, each with the intensity of 1 lumen per unit solid angle.
The luminance (and hence the brightness) is then how many of these tiny lights there are per square meter.
(Not easy stuff to explain either).
Wow.
Concept, I was thinking would increase brightness shown here, and done before I could try it
It’s nice to see people chime in and actually explain “torque and horsepower” of the flashlight. I UNDERSTAND it now!
sigh… i wish you guys woud give up on this issues regarding brightness or lumens.
i’m not trying to be an ignorant A…hole regarding the brightness or lumens…
you guys are killing me here…
what i’m trying to do is just to show a simple experiment that maybe someday somebody could take it further to improve it.
i already change the subject from brighter to longer throw… and i did shows just that…so what’s the big issue here?
it’s like asking which one is brighter… Skay Ray king or Thrunite TN31?
i’m pretty sure everybody have different opinion on this too.
i think this debate started with ma_sha1 post #12:
Long focal length magnifier lens can focus the beam to the wall & make the spot very bright, 10x brighter easily, but this diverge the beam and thus reduce flashlight throw.
In this case, greatly increased lux on the wall = greatly decreased throw!
This is like playing with magnifying glass to focus sun light, the focused spot is strong enough to ignite fire, but +will no longer throw long distance.
well guess what? i proved him wrong, how could you increase the lux but suffer decrease in throw?
do i need to change the subject to increase the lux and longer throw from simple light instead?
does that will make people happy here?
i guess only Old lumen post #34 says it better than anyone here…
No…
You don’t understand. If it can’t be dissected, corrected, manipulated, stipulated, debated, rejected or accepted, it can’t be discussed in a flashlight forum.
Yes, you redirected the light and it appears brighter, because it is more focused. No, it really isn’t brighter scientifically, because optics cannot increase light output. They are all just going through their usual long BLF process, let them enjoy, they can’t help it.
As for me, I think it’s a pretty cool attempt at focusing the light from your flashlights into a more usable beam. Not everyone knows the scientific correctness and the reality is “It’s just a flashlight for * sakes and it’s just a hobby, not building a rocket here, LOL. Have fun with it.
You proved him wrong in regard to flood lights, anything with a decent sized reflector will not benefit from this as shown by my experiment. It was brighter on the wall with the fresnel lens, but did not throw as far. That is quite clear.
it still can be done, however you might need different size of magnifying glasses, something that i currently don’t have nor i can’t find a big one as in 10” diameter… check your post regarding that 10” diameter monster thrower.
I’m going to pile on mister know it all here. Sorry fella, YOU are totally incorrect. Do your experiment accurately and you will find out the times are NOT the same. By putting your finger over the hose you introduced a restriction to the flow so the actual flow goes down. The only way you can maintain the same flow in the restricted line is to increase the pressure.
There are no opponents, just people wanting to clarify terminology and what was done.
If you use a magnifying glass to focus sunlight, you have greatly increased lux at the focus point, but past that point the beam will disperse and not stay focused. I think that is the clarification people want to get across.
nope… i’m still stand on my statement, with flooder lights that i’m testing… it’s definitely will not loss in throw distance, in fact it increase by many times fold, HOWEVER… using throw flashlight… it doesn’t works as well as flooder light…maybe because the way the reflector beams out the light?
i don’t know i’m not a light engineer. but it is only prove it only works well with flooder lights only…
i’m still trying to find a way to increase the throw using thrower light. that’s why it’s called prototype
using aspheric lenses won’t produce the same result…zoomable light have that square hotspot… however when you combine the zoomlight with this thing… it cancel out the square hotspot without losing the throw distance:)
my telscope only can fit Trustfire WF 502B perfectly, but not other lights that i currently own, that’s why i’m trying to build it bigger, using the same concept as telescope, but can be use with different lights
PS… the zoomie light will never out throw this device when used with trustfire 502b:)
What you need to take into account is the effect that ‘spill’ has on your eye’s pupils. The intensity of the foreground spill will affect your perception of the hot spot in the distance. If your pupils have ‘stopped down’ to handle the light in the foreground then the hotspot will appear dimmer. Concentrate all the spill into the hotspot then the ‘throw’ will appear brighter because your pupils will be open wider (much like DayLighter’s auto camera’s apeture).
I can see both sides of the argument here. There is less light but it’s put where it’s needed. This is why the Jacob A60 is still well thought of as a thrower even though it is low on lumens.
By the way a fun experiment & another excuse to play with my torches.
BTW Have a Happy New Year everyone.
judging on your comment, i guess you didn’t see the last picture that i posted?
you didn’t gain any knowledge on that experiment?
is my creation will less usable and effective than something i can buy?( don’t know about cheap) absolutely…
it’s an idea that i created and hoping will spawn another idea, a better one …
but if we can only be happy with 1 king thrower such as TN31 and 1 flooder maybe something like TK75…then who need idea? then who need forums like these ?
i’m pretty sure you owned more than 2 flashlights… and maybe getting more in the future.
but if there’s an idea out there that can make all the lights that you own and turn it into “monster”light… wouldn’t you want one?
and where do you think those idea will come from?
it’s the people like me who like to waste their time and money trying build something to improve what we have own already.
as far if it work well or not? there’s only 1 way to find out.
so…it probably will be much nicer if you can come out with something nicer build and share it with others instead raining on others parade
The problem is it doesn't turn it into a monster light... It may turn a flooder into a thrower, but why not start with a thrower in the first place? And while yes, you are modifying lights; so am I. The difference is I understand what I'm doing and actually make it brighter. (Driver swap, or LED swap, or more LEDs) Either way, Happy new year!
You have an idea, an interesting one, but your initial claims were made based on an incorrect use of terminology. Yes, it’s brighter, but an increase in light on the target doesn’t mean an increase in light from the torch. I certainly don’t want to bash you or stifle your creativity but the rampant inflated claims of run time and output by marketers make people trigger happy when new claims come out and it was too easy to spot the flaws in your statements. What you’ve done could save a life someday. Well done. I hope you have learned a bit more about flood vs throw and the trade offs between them when focusing light. Thanks
