Longer throw without changing the driver !! :) Prototype is done and now it's time for testing.. ( more beam shots)
I was quite busy lately (I moved) and so I missed all the fun... (and fortunately the nasty parts, too.)
I still feel like adding some remarks... (an optics related thread without me? No way ^_^ )
Be careful with analogies: Do a water hose and a flashlight really have that much in common? Try obstructing part of the beam - does the light come out at higher speed or throw farther?
(There's some fun though: Cut out a disc of cardboard about 2/3-3/4 of the flashlight's aperture's diameter and use some removable glue to fix it in the center of the front lens, compare with&without ^_^ )
Use proper terminology: A big part of this discussion was caused by misunderstanding each other. That's the reason why terminology was invented - to make sure everyone is talking about the same.
("Brightness" btw is not that well defined... Earlier it was defined as luminance, nowadays it's recommended to use it for subjective, non-quantitative perception. I think it's safe to say that this fresnel mod gives a brighter spot. It might even be valid to say that the little experiment I supposed above might give a brighter spot, though I'd find that quite confusing to say ^_^ )
I’ll try to help here. Feel free to step in GottaZoom. Simply stated, the issue arises when the hose id is larger than the supply. When that is the case pressure in the hose is LESS than pressure in the supply pipe. Therefore the pressure in the hose can rise when you put your finger over it until it hits the same pressure as the supply. Up until that point flow stays the same due to the pressure rise in the hose. It is after this point that the flow actually falls.
I think we have different opinions about what "put your finger on the hose" means. That could explain most of the confusion..
My science tells me the increase water velocity will make up for the decrease in flow area, i.e. flow rate stays the same. Common sense tells me when you adjust the faucet it takes longer to fill up containers. So I went out to the garage and open the faucet about half-way. Counted how long a small bucket filled up water coming out of the hose unhindered(took about 10 seconds). Emptied the same bucket and filled it up again but this time I partially blocked the end of the hose (about 75% blocked) and it took about 10 seconds also for the bucket to fill. I guess my results means I’m going to side with GottaZoom and NZShooter on the flow debate.
As DrJones pointed out, all this is irrelevant. The speed of light is fixed and can't be faster than it is. (Yes, I understand this oversimplifies it)
i’m glad you can chime in on the subject Drjones… maybe now we can put this all corrective term of brightness behind and move on the original purpose of this little experiment… which is just an IDEA.
an idea that maybe can be use to further more testing and creation to brighter lights without spending a lot of money in the future :smiley:
Never mind the science, common sense should tell you it would take longer to fill the bucket at 99% blocked.
I have always found it useful to exaggerate an issue to see it more clearly.
In electrical circuits, one can emulate a constant current source by having a high voltage power supply in series with a high resistor. For example a 300 volt source in series with a 300 ohm resistor will give 1 amp to a 1 ohm load. It will also give 1 amp to a 2 ohm, or 3 ohm load. In other words, it would appear to be a constant current source.
This water and hose example appears to be a constant flow source because the relatively high resistance of the length of garden hose. Within certain changes in the restrictions at the end it can appear as a constant flow source.
In the above electrical circuit, placing a higher resistance load it becomes apparent the the supply is NOT a constant current source. (a 600 ohm load will only draw 1/3 amp)
[quote=NightCrawl]
[quote=GottaZoom]
Our pump doesn’t care whether faucets are open or closed. It runs by timer because it is for irrigation and always has a form of pressure relief, regardless of whether the 2 garden hose faucets are open or closed. Thus it never has fixed pressure level, (unless I gate off the irrigation and close all of the faucets, in which case a pressure relief valve will open and hold pressure to protect the pump). Our system is more of a constant flow system, actually somewhat similar to the professors assumption (though we can tune for varying power, pressure, and thus output). Pumps generally won’t pump pressures greater than the system if it was built well. Generally a relief system is designed in (especially when built by someone smarter than me) to protect the pump and system. The primary risks in our system are a waste of energy and pump life.
Um… just wondering,can we go back to *my idea*and see how we can improve this idea into a better one? :Sp
Funny thing is you helped come to that conclusion by not opening the faucet all the way. Depending on other factors it might be different. It’s that complexity that keeps me asking questions.
While we practically cannot speed up light, most of us aren’t measuring speed. We’re observing volume in full or in part. Blocking the beam by redirection to change the locally observed volume is exactly the point of the thread. Sometimes an analogy is useful, if not exact.
Here’s a short video of a fresnel lens moving in front of an UF2100 running on 20%:
Quality isn’t the best because it’s a soft (flexible) lens and I just moved it with my hands. I left ambient light on to reduce brightness adjustments in my camera (compact camera, no manual settings)
However you see that it is indeed similar to a zoom light as there’s a position where LED and reflector are projected onto the wall. Near that position however there’s a position where that image is blurred into a quite good and quite bright spot.
Fresnel lenses are quite lossy, quite dome of the light is scattered at the edges. A real lens of same size would give a better performance, pot probably some more artifacts, too. Main contribution to throw is lens size and quality.
A high quality aspheric lens with same area and with a (bare) LED in it’s focus will have the best throw, but a smaller spot.
yeah, that was the base of my experiment, now i’m trying to move into adding combination of different lenses to see if i can manipulate lights into thrower or floodier ( for bike light)
i want to buil something like light device but in smaller scale :smiley:
maybe you can give me some input on these experiement, i found a success hooking my Trustfire WF 502B into telescope and it able to throw as far as 300’+, but the hotspot starting to dissappear and turn into a doughnut … but it still reach :slight_smile:
now… if i can somewhat miniaturize this device using combination of telescope optics ( which i have plenty of) that will be great
So, did you construct the apparatus as the OP described? From what I read just now, it would appear that the experiment wasn’t repeated.
By ANYone.
Sorry to butt in, but I take exception to misuse of the “S” word…
ALL of you could do well to revisit the Michaelson-Morley experiment right about now…
Waves don’t travel, particles do. Where do they all go?
I’m just sayin…
But I’ll go back to reading, it’s only page 4…
Dim
THANK YOU!!!
I was about to explode! :beer:
All I know is, I can throw my F20 a lot farther than it can throw back! :smiley:
Some of us “light is particles” crowd do seem to think that pulling all that light into one spot SHOULD push all those photons a lot further down the road…
Even if we “light is waves” types understand propagation of energy, and can actually draw the line for the Inverse Square Law…
Mainly, this is AWESOME to read!!!
8)
Dim
Don’t forget the reflective cylinder … :zipper_mouth_face:
Only if you put the LED at the exact point your eye would be. At least on my spotting scope that’s how it works. Ironically this “throw” works better with an XM-L (being closer to the exit pupil size), at least with mine. Try it through a rifle scope…
And yes, works quite well to put a very bright spot on something a long way away.
Now if I could line the barrel of it with reflective foil like the OP……. :nerd_face:
Dim
Uh…
I’d bet the farm that ma_sha1 can. :crown:
But it won’t be $15 any more!! H)
using binoculars won’t work too well, as they have 2 lenses spread far apart, the telescope experiment was using 2 lenses but they’re very close to each other :). if you using freshnel lens (magnifying glass) you will see the result similar to mine :wink:
then your horses aint gonna have barn anymore :wink:
