Aside from the bezel not screwing down, the rattle inside the head and the green to purple tint.
Now it is stuck at 1 brightness level (one of the mids I think) and it cant be changed, the flashing modes still work but appear to be only the same brightness that the light is stuck on.
I just changed the batteries and it seems ok, I didn’t notice the blue LED flashing fast but I wasnt really looking either.
I’m going to feel silly telling him that… oh well. I’ll tell him after he replies.
But still I forgot to mention here the dark artefacts in the hotspot as well, if its on something less than 10 meters or so away and move it, its quite easy to follow the dark patches and even 1 section of it looks brighter than the rest. I could see orange flecks on the inside of the dome, it kind of looks like rusty orange lint.
I don’t really want to send it back but a $59 light should be flawless, shipping will cost $20+ from here as well.
He said they checked them all and sent the worst ones back and that Nitecore already knew about the problems with them.
I sent my first one back after noticing what seemed to be a cross threaded bezel. The replacement is pretty much perfect. Still has a slight rattle, and there is still a slight gap in the bezel but from what I've been reading, it's totally normal. The rattle is slight and also very common. Not really bothered by that. The beam looks good on mine. I'm not noticing any obvious artifacts.
BTW, Illumination Supply paid for my return shipping!
That's great! Hopefully you get your replacement in a timely fashion. It really is a nice light. I wish Nitecore would get their QC together. I think they rushed them out unfortunately..
i think if they do a second run, more threads on the head or a shorter bezel will get the bezel sitting nice and flush to the head. and the derlin ring needs to have the tolerance a little tighter to keep it snug around the base of the reflector. besides that i think its a pretty solid light and cant wait til i can get one
now the cross threads on yours is sure a qc miss though
I was thinking of taking mine apart and putting a couple of very small dabs of silicon sealer on the derlin ring so it doesn't rattle. At least gap in my replacement is even. All of what you said above should have done from the start..
To better understand the UI, I created a colour-coded Quick Reference Guide or cheat sheet for the EA4 (in PDF format). You can download it from the following link…
