Whats the best thermal compound?
63 posts / 0 new
Bort
Bort's picture
Last seen: 7 hours 50 min ago
If i want to someday build an XM-L2 on copper high amperage light, i want the best heat transferring compound, so please toss in your suggestions
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
Edited by: Bort on 01/08/2013 - 01:40
Rezolution
Rezolution's picture
Arctic Alumina or Fujik
ezarc
If you can screw it down then a good cpu thermal paste will probably be the best.
If it also needs to stick it there then I couldn’t say its the best but Fujik does the job well. It will cure like silicone if you ever want to remove it as well.
bose301s
bose301s's picture
Last seen: 1 year 6 months ago
No and hell no.
Look up Parker Chomerics, PPTk recommends them and I had good luck with their products for an internship project.
DARCANGEL
DARCANGEL's picture
Wakefield deltabond 155Laughing.
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 11 months ago
If the copper and the heat sink are lapped and the two bolted together, then a good thermal paste would work fine.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
rojos
Last seen: 6 years 9 months ago
Look here: http://budgetlightforum.com/node/13413#comment-233314
PPtk says Wakefield for adhesive, Parker for grease.
And like OL said, lap the mating surfaces.  The condition of the mating surfaces will impact performance more than your choice of compound.
Hikelite
Last seen: 48 min 51 sec ago
Fujik(BAB 900) is 0.88W/m.K, that is  poor to say the least.
Hikelite
Arctic MX-2 is appreciated in the CPU world. It does not have a curing time like AS5. But as will all thermal compound greases you need pressure for the best performance.
jufran88
jufran88's picture
Last seen: 6 years 5 months ago
Shin-Etsu MicroSi G751 is probably one of the best I’ve used.
Hikelite
This Shin-Etsu X23 paste looks good in this ranking. Basically they are all very close.
http://img.photobucket.com/albums/v722/Duane_Bolt/tim.jpg
Pulsar13
Pulsar13's picture
Last seen: 4 months 1 week ago
Does anyone here actually use screw for the star? Just curious. Any good tools for threading?
BILL G
Last seen: 7 years 1 month ago
I RX 4g of MX-2 for $4.99 FS from SuperBiiz.com
ezarc
I don’t myself but you can get a basic tap and die set for about $15-20, a good set could cost in the $100s.
dthrckt
dthrckt's picture
Last seen: 1 week 2 days ago
I’ve never needed a tap to put little screws in aluminum…just use the screw as you would a tap.
Copper is a different story, and trying to do that same thing is a good way to shear the head off a screw and leave the body in your hole |(
anyway, they’re cheap enough individually to be worthwhile. pick the screw you’ll use first….
http://compare.ebay.com/like/390456861791?var=lv&ltyp=AllFixedPriceItemT...
Uldzha
Uldzha's picture
Last seen: 6 years 4 months ago
I once thought this idea:
If you have a Copper LED star and Brass pill – maybe can use the soldering between them? It has a much better heat transferring.
If anyone has tried it? Smile
dthrckt
dthrckt's picture
I’ve been planning to.
but, I don’t think it has better heat transfer than well lapped parts
http://www.electronics-cooling.com/2006/08/thermal-conductivity-of-solders/
it does preclude the need for glue or screws though…
mattthemuppet
I vote for toothpaste – cheap, clean and minty fresh.
I almost always lap my stars+base, then screw them down (usually 4-40 taps and screws). Thermal transfer is so good that I struggle to solder the wires onto the star. In this situation, thermal pastes are a much of a muchness – the cheap chinese stuff seems to work as well (qualitatively) as the Chomerics sample I got. However, the Chomerics stuff is much easier to apply and spreads out more evenly, so if you can sweet talk them into a sample go for that.
No idea on adhesive thermal compounds though, as I’ve never used them.
NightCrawl
Last seen: 6 years 8 months ago
dthrckt wrote:
I've been planning to. but, I don't think it has better heat transfer than well lapped parts http://www.electronics-cooling.com/2006/08/thermal-conductivity-of-solders/ it does preclude the need for glue or screws though...
The LED is fixed to the star with solder, so that shouldnt be a problem. Wink
dthrckt
dthrckt's picture
NightCrawl wrote:
dthrckt wrote:
I’ve been planning to. but, I don’t think it has better heat transfer than well lapped parts http://www.electronics-cooling.com/2006/08/thermal-conductivity-of-solders/ it does preclude the need for glue or screws though…
not sure what you mean.
adding another layer of solder (low thermal conductivity vs aluminum, copper and brass) isn’t going to improve anything
there are real world tests of the two configs (mated parts vs soldered parts) that can be found with google…
anyway, if you have a brass pill, skip the pcb and solder the led to the pill…
AlexGT
AlexGT's picture
Last seen: 1 day 11 hours ago
How do you lap the inside of the pill where the base of the star will sit? Usually they have a rim around the flat surface, please explain what tools do you use to lap it.
kevind43
Last seen: 2 weeks 4 days ago
screwing the pill down is a very good way to do it. but if you have never drilled and tapped a hole i suggest you buy multiple drill bits and multiple taps and practice on similair material before you attempt working on that emitter pill. working with such small drills and taps such as 2-56 or 4-40 requires a learning curve Wink
Pulsar
Pulsar's picture
i cant suggest whats the best. but optimum conditions using a thermal compound is having both the mating surfaces as smooth and flat as possible. you also want as little thermal compound between those surfaces as possible. the purpose of thermal compounds is to fill in the microscopic pores and scratches. if possible, compressing the parts together to get as much unneeded compound squeezed out from between them possible would be great too
dthrckt
dthrckt's picture
I unsolder the emitter, take a steel punch that has a flat face, set it on the pcb and hot glue it in place. sometimes I use a cordless drill to spin it slowly, some times I do it entirely by hand (takes awhile).
I use 600 grit lapping compound and then alumina, i forget the micron size but it is equivalent to 1200 grit (mixed with water or mineral oil).
like matt mentioned – it makes it difficult to solder leads to the pcb because the heat transfer is so much better. I just prop the edge up a bit w/ something in order to solder
here is how much contact a typical stock pcb has (the dark portion only)
eventually, the whole thing is dark. I scrub with a toothbrush afterwards to get alumina out. then wipe thermal grease onto is as thin as possible.
and as you can see, I just watch a movie while doing it, so it doesn’t feel like a big waste of time Smile
mattthemuppet
I don’t work much with torches (mostly bike lights) so I couldn’t really tell you, but for lapping flat surfaces and stars I use 400>800>1000>1500>2000>Mothers Mag polish with plenty of water/ spit on the wet’n‘dry, using the flat on my vise as a flat surface. You can easily feel the difference with your finger tip afterwards Smile
To do a pill, I would probably get some wood dowel 1/2 to 1/4 the diameter of the pill and wrap the sandpaper over the end. It’ll be fiddly, but with some patience you should be able to get it smoother at least.
I would really caution using screws with small stars as the screw heads can easily interfere with the optic or reflector. I’ve never had problems with 20mm stars, but the one 16mm star I used in a recent build was a complete bear. Get the smallest flattest screws you can find if you’re going that route!
dthrckt
dthrckt's picture
to be clear, I mate the pill and pcb when lapping, I don’t just flatten them. though judging from the pcbs I’ve lapped, even just flattening them would be a significant improvement.
NightCrawl
dthrckt wrote:
not sure what you mean. adding another layer of solder (low thermal conductivity vs aluminum, copper and brass) isn't going to improve anything there are real world tests of the two configs (mated parts vs soldered parts) that can be found with google... anyway, if you have a brass pill, skip the pcb and solder the led to the pill...
If you have a copper pcb and a brass pill, soldering those together is superior to almost anything except for extremly tight lapped surfaces.. there is already a solder connection between the heat source (=LED) and the heatsink (=PCB), so adding another one to connect the PCB to a larger heatsink cant have a negative influence. On cpf I read that someone grinded down the bottom of emitters and glued them on with something really good.. I mean there is stuff with better thermal conductivity than aluminium, its just very expensive. I think it was linked in the "lets discuss heatsinking" thread.
But yes, stock PCBs have very poor connection because they are so uneven.
For P60 pills: I wouldnt mind removing the rim, havent noticed any negative effects so far.
As for lapping: I find it easier to flatten pcb and heatsink first with sandpaper and bring them to a mirror-like finish, going up to 2500 grid. Then some lapping and you are done, although its better to be good at sanding than to be bad at lapping. Wink
Slim Pickens
Slim Pickens's picture
Last seen: 1 month 1 week ago
Nice tips, guys. I usually use 000/0000 steel wool followed by Brasso or Mother’s until both the PCB and heatsink shine.
dthrckt
dthrckt's picture
like I said, well lapped is superior.
soldering them together DOES have a negative influence vs lapped….it adds an additional layer of metal that has a lower thermal conductivity…
there is stuff w/ better thermal conductivity than aluminum, but it sure isn’t solder.
would soldering be better than unlapped pcb with thermal paste. sure, unless you use way too much solder.
now, with a copper pcb, that likely has a gold coating to resist tarnish, solder might be wiser than lapping in the long term, since you’d remove the gold when lapping…
have you ever lapped a pcb? try it Smile
Old-Lumens
Of course, the whole discussion is sort of a mute point. Real world, single emitter lights don't have to go to extremes, just clean the surfaces and apply whatever you want, either thermal compound or thermal adhesive and give it some pressure. Good enough for 95% of the lights out there and only a highly modded "hot light", would really need the extra attention.
Even with those, most of us would use it a few times, for short periond and then put it on the shelf, sell it, trade it, or give it away, so in 99% of the cases, it's not really a big issue, it's just an issue in our minds.
dthrckt
dthrckt's picture
Old-Lumens wrote:
Of course, the whole discussion is sort of a mute point. Real world, single emitter lights don’t have to go to extremes, just clean the surfaces and apply whatever you want, either thermal compound or thermal adhesive and give it some pressure. Good enough for 95% of the lights out there and only a highly modded “hot light”, would really need the extra attention.
Even with those, most of us would use it a few times, for short periond and then put it on the shelf, sell it, trade it, or give it away, so in 99% of the cases, it’s not really a big issue, it’s just an issue in our minds.
yup
mating parts by lapping takes too long to ever be used in production, or by people that aren’t as silly as I am. soldering would takes seconds…
