Pretty much all thermal compounds perform the same! The main difference between a good and poor compound is the long term stability of the carrier fluid used to make up the paste.
Sorry, I’m thinking everyone knows what I’m on about, on both the Jacobs and the ke-5, there is no pill, the light engine is part of the host, as such, its anodized just like the rest of the host, so I sanded and polished under where the star will sit, so the star was pasted direct to the host alu, rather than there being an anodized layer between the base of the star and the aluminium of the light engine, now I see, I should have also polished the base of the star flat too, something I’ve wondered about.
Lapped might be superior when done professional. With home tools? I'm unsure..
How could soldering have any negative effect? You already have a layer of solder between LED and PCB, but the layer between PCB and heatsink would have 10times the area -> better heat conduction. If you have a 1" pipe at the source it doesnt matter how many 1" pipes you add in the path, even if some are 3"..
Actually aluminium PCBs would be great if you could solder the LED directly on the aluminium, without the dielectric layer and all that stuff inbetween. Thats the main advantage of copper pcbs. I think even brass PCBs would be better if its a good alloy.
And I dont think the gold layer has any influence on thermal conductivity at all. Its there so the copper doesnt oxidate. Also, even those copper PCBs from LED-tech are uneven because they are punched out..
@ChimpOnABike: CPU heatsinks arent lapped because you need both parts for lapping. They are sometimes sanded pretty good, but often far from a mirror-like finish. Its an easy improvement actually.
Something with powdered diamond in it. Diamond powder is actually not too expensive. Check Ebay: Shop by Category | eBay%28dust%2Cpowder%29&_sacat=3213&_odkw=diamond%28dust%2Cpowder%29+mesh&_sac=1&_osacat=3213&_from=R40
well, I have lapped machined parts professionally, but I don’t think someone else needs to have been paid to do a good job. it does take some patience.
there isn’t any fluid mechanics involved here, so fluid in pipes isn’t a good analogy.
i’m not sure how to explain it differently. Maybe we’ll have to agree to disagree.
the thermal conductivity of solder is lower than the metals involved, so putting it in between them reduces thermal conductivity if they have very good contact before soldering - what happens before or after that can change the temperature gradient in operation, but not the properties of the materials at the junction.
I guess we’ll have to agree disagree.
you can solder aluminum, but it requires a different solder, or at least a different flux, and it is a PITA
any material will have ‘some’ influence but it’d be near impossible to measure
anyway, I didn’t mean to imply that’s why gold shouldn’t be removed…I meant you don’t want the copper to tarnish…which would surely reduce contact area as well as thermal conductivity…
anyway, let me know when you find copper PCBs, I’d be happy to test this scenario.
I meant with the proper tools, not necessarily paying someone to do that..
Its the easiest I could think of.. I'm not good at calculating, but as there already is solder involved right under the LED, it cant really get worse. Maybe someone who knows how to calculate that stuff can chime in..
Metal to metal is of course superior, but if someone doesnt have the tools or patience, soldering is as good as he can get. Agreed? :D
I know, I did it before.. but as you said, not easy and therefore (I guess) rather expensive to produce. So they dont..
Well, gold is worse than copper, so.. :P
And yes, its there so the copper wont tarnish and its easier to solder to. But if you plan on using the copper stars from LED-tech, you better sand them, because they arent much better (regarding how even they are) than all those aluminium stars.
You guys gave me an idea on how to lap the insides of the pill very flat
I currently lap my stars on a flat piece of glass using wet/dry sandpaper progresively up to 2000 grit.
For the pill I am thinking on using a steel bolt like this
And lap the bolt’s head flat on a glass using wet / dry sandpaper up to 2000 grit and then glue wet / dry sandpaper to the bolt’s head and lap the inside of the pill up to 2000 grit using a drill, IMHO it should produce really good results, what do you guys think?
I’m familiar with the calculations, although admittedly not as familiar as when I passed thermodynamics w/ an A grade 16 years ago…
The problem with calculating this is, interfacial thermal resistance is empirical.
I like this stuff, so I spent a couple hours last night looking for test data. ( No mystery why I’m single )
I couldn’t find a study of ‘copper to copper’ vs ‘copper to solder’ interfaces. The closest I could find, in different studies, was that a milled copper to copper interface (1.6um roughness…not lapped), with no thermal compound, is has an order of magnitude lower thermal conductance than a copper-solder-copper sandwich where the solder is <30um thick and has above average (for solder) thermal conductivity. Of note, a copper-copper interface that is ground (3.6um) is 3x worse than milled…
So…I find that data interesting, and pointing in the direction of solder being superior…but ultimately inconclusive…
If you’re good at soldering
I definitely think soldering is easier - although it doesn’t preclude lapping…in fact the copper solder sandwich study used lapped copper discs….
I picked up a good tip from that study. calculate the amount required to cover the contact area with 10um layer, use a little excess, press the parts together while still hot to squeeze out excess.
anyway, maybe some day we’ll get to test this. unfortunately, the studies I found use a laser for heating and very accurate measuring equipment…which to me implies, even if we get the chance to test, we’d be hard pressed to tell the difference w/ ‘amateur’ test equipment :bigsmile:
Also a suggestion to use as little compound as possible just to fill in air gaps (if the compound is more conductive then the metals then this advice may be mute?)
Can somebody wade through these and figure out the best 3?
yes as far as use as little compound as possible, the compound will not be superior to metal.
if you’re not going to screw down the PCB, then you will need adhesive compound.
the technique (or at least my technique) is different for adhesive compound.
Since I flatten/lap the surface, I apply grease-like compound to both surfaces, rub it in to eliminate air, then scrape it off with something flat.
For adhesive, I apply to both surfaces, rub it in, then clamp the two parts together, so that excess squeezes out, and pressure is maintained while the adhesive sets.
the only adhesive thermal compounds I’m familiar with are fujik and arctic silver adhesive.
Start at the top of the chart you linked, search the product name (ie the products that don’t say they’re a grease) and when you find one that’s adhesive, and above arctic silver adhesive in the chart…you’ve got your answer
It depends on which compound you use as some are worse than others. Anything with high levels of silver and given enough of it you run the risk of Argyria, although I totally accept this is low risk unless you’re using it on a daily basis. I can’t find the link (it was back in my PC modding days several years back) but I have seen dermatology people talk about problems with the very fine particle size and skin reactions. Either way it’s best not to eat it or get it on skin, although you won’t drop dead on the spot if you do.
